Analyzers
5248 Discussions
Vtune-Sampling Wizard Error: can't create activity
cswodi
I download Intel VTune Analyzer for Linux*(vtune91_008_lin.tar.gz) and install at fedora 9.
my computer cpu is Intel Core i7-930 processor .
I want tocreate the project through : File->new->project->Sampling Wizard->next->(Application to launch:/opt/intel/samples/vtunedemo/vtunedemo) and Finished.
and then a dialog box titled "Sampling Wizard Error" appears to me with the following message: "Can't create activity".
Please someone has an idea?
Someone tell me that I should update something , but i still don't konw something means .
Peter_W_Intel
You may check below things:
1. Have you seen any error message when installing the product? Or check /var/log/vtune_install.log
2. Ensure that vtune driver has been built and loaded in your system. "lsmod | grep vtune"
3. Use command line to know if sampling data collector is workable. "vtl activity -c sampling app /bin/ls run"
4. If everything is OK. Maybe your workspace is damaged or with write-permission issue, please change vtuneworkspace (when launching vtlec) to other directorywhere you have write-permission.
Hope it helps.
Regards, Peter
Peter_W_Intel
Hope it helps.
Regards, Peter
cswodi
I check the install log and find the vtune driver build error.
Then i install the kernel-devel package and re-install the vtune.
Now everything is ok!
thanks.
