Analyzers
Vtune advanced-hotspots not capturing entire workload
Braxton_T_
  I am trying to run vtune 2017 with the advanced-hotspots collection, and it does not seem to be capturing the entire run. Example output:
Collection start time     14:13:31 04/10/2017 UTC
Collection stop time      15:09:21 04/10/2017 UTC        CPU
Parameter          r012ah
Name               Intel(R) Xeon(R) E5 Processor code named Jaketown
Frequency          2693511693
Logical CPU Count  32
Summary
Elapsed Time:       3349.496
CPU Time:           3327.408
Average CPU Usage:  0.988
CPI Rate:           1.043
LD_LIBRARY_PATH= /home/tools/intel/vtune_amplifier_xe_2017/bin64/amplxe-cl     24505.38s user 220.91s system 100% cpu 6:50:30.18 total
So I ran this with 'time' wrapped around it, and time reported the entire thing took 24505 seconds, and it actually ended at approximately 21:00 UTC - but vtune is reporting a collection stop time of 15:09 UTC.
This same command line works with the non-advanced hotspots collection (and took around 32k seconds). This is repeatable - I have not been able to get advanced-hotspots results after many tries. I am not sure what could be going wrong - it seems like the collector is just dying. Sometimes I only get 60-100s of collection range for a 6 hour run.
Thanks in advance,
Braxton
Dmitry_R_Intel1
The first thing that comes to my mind is Data Limit option. By default VTune stops collection when amount of data reaches 500MB. So if you haven't adjusted this limit it could explain the behavior you are seeing.
To turn off the data limit add '-data-limit=0' to the amplxe-cl command line.
Also - did you see any errors or warning in console/collection log during the profiling run?
TimP
For long runs you should reduce sampling rate so as to avoid approaching data limit or spending much time interrupting collection while saving to disk.
Braxton_T_
Aaaagh, yes, that was the problem.
I had recently upgraded from the 2013 version, which did not have this behavior (or at least the defaults were different).
Sure would be nice if the tool said "Hey I stopped collecting because I ran out of allocated space".
