Analyzers
5201 Discussions
Vtune assertion failed- Linux/chromeOS
Vaibhav_S_Intel
Vtune assertion failed during hotspot analysis on ChromeOS(ADL). Can you please check the attached logs and let me know the WA for this issue.
(Virus scan in progress ...)
JaideepK_Intel
Can you try to run Vtune on a supporting operating system? Chrome OS is not mentioned in the Vtune system requirements.
Link: https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
From the crash report, I can see you are using an older version of Vtune, i.e. 2022.1. Can you update your Vtune profiler (2022.3) to the most recent version and test it?
Link: https://www.intel.com/content/www/us/en/developer/tools/oneapi/vtune-profiler-download.html
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
Vaibhav_S_Intel
Hi Jaideep,
I tried initially with the latest Vtune as well. I still see the same issue-- assertion failure on ADL based systems. I'm using sepdk build as the driver that came along with Vtune
Vaibhav_S_Intel
attached latest logs from vtune
JaideepK_Intel
As per system requirements, we can not run Vtune on Chrome OS. Can you try to run Vtune on a supporting operating system? and if the issue still persists, please let us know.
Jaideep
JaideepK_Intel
Jaideep
Vaibhav_S_Intel
Sorry i dont have acces to other OS and i mainly work on ChromeOS. I need Vtune team to support me on that.
JaideepK_Intel
We are working on this internally and get back to you with an update.
Thanks and Regards,
Jaideep
JaideepK_Intel
As we discussed privately, we are closing this case from our end. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
