When I am using Vtune as non root user to capture memory-consumption in linux OS (NAME="Rocky Linux"
VERSION="8.10 (Green Obsidian)"/ x86_64 x86_64 x86_64 GNU/Linux) I am getting the following error :
(application running as non-root).
vtune -collect memory-consumption -target-process a.out -result-dir /opt/sdl/collect/
Intel(R) VTune(TM) Profiler 2025.0.1 (build 629235) feedback tool
Copyright (C) 2009 Intel Corporation. All rights reserved.
Intel(R) VTune(TM) Profiler 2025.0.1; 629235 experienced an unexpected error.
Please send a problem report:
amplxe-feedback --send-crash-report "/tmp/amplxe-log-sdl/2025-03-07-09-02-02-881120.amplxe-runss/crash_info.txt"
Report data may be used to improve product stability. Our apologies for the inconvenience and thank you for your assistance.
Exception: 0xb, Segmentation fault
Module: libc-2.28.so
Collecting modules information...
Collecting system information...
sh: /tmp/amplxe-log-sdl/2025-03-07-09-02-02-960821.amplxe-feedback/qfagent.cmd: Permission denied
However, if I run the vtune as root user and application running as root no issue is observed. How can resolve this issue.
Thanx
Abhijit
'Permission denied' means current VTune permission is denied to attach and analyze the the target process. Is the target-process a.out a system process? Or is it not the same user for VTune and the target process?
