Analyzers
5253 ディスカッション
Vtune issue in MacOS version
YWang84
ビギナー
1,596件の閲覧回数
I am using MacOS version VTune gui to profile a remote process launched in a Linux box. But then got this issue:
amplxe: Error: Stack size provided to sigaltstack is too small. Please increase the stack size to 64K minimum
It looks the recommendation is to apply "-run-pass-thru=-no-altstack" follows the amplxe-cl. This option seems not working in MacOS version VTune, but how to pass it to remote Linux vtune profiler?
0 件の賞賛
6 返答(返信)
Kirill_U_Intel
従業員
1,596件の閲覧回数
Hi Yujia.
Could you share your amplxe-cl command?
I verified this one
./amplxe-cl -target-system ssh:USER@HOST_API -target-install-dir=REMOTE_VTUNE_DIR -collect hotspots -knob sampling-mode=hw -knob sampling-interval=1 -run-pass-thru=-no-altstack -- /bin/ls
and option was added without any problem.
I've just copied command line to clipboard in GUI and added -run-pass-thru=-no-altstack.
Kirill
YWang84
ビギナー
1,596件の閲覧回数
Hi Kirill,
Thank you for reply. It looks works with a CLI issued from Mac.
Is this option (-run-pass-thru=-no-altstack) working in GUI? Can I run this from GUI?
Another problem is that if I succeed in running a collect job with this CLI.
/amplxe-cl -target-system ssh:user@IP -target-install-dir=/home/intel/vtune_amplifier_2019.0.2.570779/ -collect hotspots -knob sampling-interval=1 -run-pass-thru=-no-altstack -target-pid 25662
After a while, I stopped this and get the result dir. I wanted to import the result from GUI, but got following errors. Do you know why?
Kirill_U_Intel
従業員
1,596件の閲覧回数
Hi Yujia.
This option is not available from GUI but we are in implementation stage for automatic switching on this flow in case of such issues.
Why did you use import for results? You must to use 'Open Result' dialog (not Import)
Kirill
YWang84
ビギナー
1,596件の閲覧回数
You are right! Open result looks good. What does "import results" do?
BTW, how can I profile by launching an application?
amplxe-cl -target-system ssh:splunk@azhang-splunk2
 -collect hotspots -run-pass-thru=-no-altstack -- "/home/MyApp start"
I tried this and it cannot be executed. What is the correct way to apply parameters to my launched app?
Kirill_U_Intel
従業員
1,596件の閲覧回数
Some words about import
https://software.intel.com/en-us/vtune-amplifier-help-importing-results-to-gui
just remove quotes to run application with params.
 -collect hotspots -run-pass-thru=-no-altstack -- /home/MyApp start
YWang84
ビギナー
1,596件の閲覧回数
You are super!
I am afraid one potential issue is that my application's start requires a 30 seconds to start, with this profiling mode - to launch the application with amplxe cli. It get stopped with bad result finally for unknown reason. But I can use --targe-pid to work.
返信
