Analyzers
Vtune not able to identify processor type
somayajula__asha
Hi, Vtune when trying to find the hotspots is not able to identify the processor type. Althought its a MAC OS with i5 installed. Can anyone post a solution for the issue?
Asha
Kirill_U_Intel
Hi, Asha.
Could you share output from vtune tools?
VTUNE_INSTALL_DIR/Contents/MacOS/amplxe-runss --context-value-list
VTUNE_INSTALL_DIR/Contents/MacOS/sep -version
Thanks, Kirill
gfoidl
I have a similar problem with my i7 cpu.
Intel VTune Profiler 2020
Product build: 605129
Output from amplxe-runss --context-value-list
targetOS: Windows
OS: Windows
OSBuildNumber: 18362
OSBitness: 64
AdministratorPrivileges: true
isPtraceScopeLimited: false
isCATSupportedByCPU: false
isTSXAvailable: false
isHTEnabled: true
fpgaOnBoard: None
omniPathOnBoard: None
pciClassParts:
isSGXAvailable: true
Hypervisor: None
PerfmonVersion: 4
isMaxDRAMBandwidthMeasurementSupported: true
areGpuHardwareMetricsAvailable: DriverNotResponding
ETW: OK
isGpuBusynessAvailable: yes
isGpuBusynessDetailsAvailable: notAccessible
isGpuWaitAvailable: no
isEtwCLRSupported: yes
isFtraceAvailable:
isMdfEtwAvailable: false
isCSwitchAvailable: yes
isFunctionTracingAvailable: no
isIowaitTracingAvailable: no
isVSyncAvailable: na
HypervisorType: None
isDeviceOrCredentialGuardEnabled: false
isSEPDriverAvailable: true
SEPDriverVersion: 5.14
isPAXDriverLoaded: true
PAXDriverVersion: 1.0
platformType:
CPU_NAME:
PMU:
referenceFrequency: 2800000000
isPStateAvailable: true
isVTSSPPDriverAvailable: true
isNMIWatchDogTimerRunning: false
isTPSSAvailable: true
isPytraceAvailable: true
isGENDebugInfoAvailable: false
isGTPinCollectionAvailable: ErrorUnsupportedHardware
isSTTAvailable: no
isEnergyCollectionSupported: true
isSocwatchDriverLoaded: true
Output from sep -version
Sampling Enabling Product version: 5.14  built on Nov 26 2019 11:44:09
SEP User Mode Version: 5.14
SEP Driver Version: 5.14
PAX Driver Version: 1.0
Platform type: 117
CPU name: Intel(R) Processor code named Kabylake
PMU: skylake
Driver configs: Maskable Interrupt, PEBS OFF (by OS security), MULTI PEBS OFF (tracepoints not accessible)
Copyright(C) 2007-2019 Intel Corporation. All rights reserved.
Cheers, Günther
David_Billinghurst
New Contributor III
Me too. When I run Intel VTune Amplifier 2019 from Visual Studio 2019 as Administrator. Hotspot Analysis shows
  • This analysis type is not applicable to the system because VTune Amplifier cannot recognize the processor. If this is a new Intel processor, please check for an updated version of VTune Amplifier. If this is an unreleased Intel processor, please contact Online Service Center for an NDA product package.
  • This analysis type is not applicable to the current machine microarchitecture
This is a new PC.  It works on my old PC.
OS: Windows 10 Pro 10.0.18362 Build 18362
Workstation: Dell Precision 5820 Tower
Processor: Intel(R) Xeon(R) W-2125 CPU @ 4.00GHz, 4008 Mhz, 4 Core(s), 8 Logical Processor(s) (skylake)
VTune Amplifier from Fortran 2019 update 5
C:\Program Files (x86)\IntelSWTools\VTune Amplifier 2019\bin32>.\sep -version
Sampling Enabling Product version: 5.10  built on Aug 19 2019 21:06:59
SEP User Mode Version: 5.10
SEP Driver Version: 5.10
Platform type: 111
CPU name: Intel(R) Xeon(R) Processor code named Skylake
PMU: skylake_server
Virtualization platform: Host VM on Hyper-V
C:\Program Files (x86)\IntelSWTools\VTune Amplifier 2019\bin64>amplxe-runss.exe -context-value-list
targetOS: Windows
OS: Windows
OSBitness: 64
isCATSupportedByCPU: true
isL3CATAvailable: false
isL2CATAvailable: false
isTSXAvailable: true
isHTEnabled: true
fpgaOnBoard: None
pciClassParts:
isSGXAvailable: false
Hypervisor: Microsoft Hv
PerfmonVersion: 4
ETW: OK
isFtraceAvailable:
SEPDriverVersion: 5.10
platformType:
CPU_NAME:
PMU:
referenceFrequency: 4000000000
isSTTAvailable: no
Kirill_U_Intel
Hi, All.
Could you share winver tool information? dialog picture?
Kirill
gfoidl
David_Billinghurst
New Contributor III
In #4 above I said that I got this problem on a new PC but not on an old PC.  No longer true.
I still have access to the old machine with Fortran 2019 u4 and VTune Amplifier 2091 u4.  It now shows the same error.  Used to work in June/July 2019.
I tried using the VTune gui directly, in case Visual Studio was getting involved.  Same result.
This has been logged with Intel as Service Request#:04468999
EDIT:  Also tried the command line interface with same result.
David_Billinghurst
New Contributor III
I wonder if this is related.  When sep -version is directed to a file the last five lines are lost
From a cmd window with Administrator privileges
C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64>.\sep -version
Platform type: 99
CPU name: Intel(R) Xeon(R) E5/E7 v3 Processor code named Haswell
PMU: haswell_server
but when directed to a file
C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64>.\sep -version > c:\temp\beehive-sep.txt
C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64>type c:\temp\beehive-sep.txt
Note:  This is a different machine to the one above in #4.  That one has the same behaviour.
Kirill_U_Intel
Was windows on the old machine upgraded?
Kirill_U_Intel
We still could not reproduce on our side :(
I used the same VTune build #605129 and the same Windows build (Microsoft Windows [Version 10.0.18362.535])
Platform type: 103
CPU name: Intel(R) Processor code named Skylake
PMU: skylake
BTW, could you make emon call 'emon -v' for both stdout and file redirection? Is there issue here?
David_Billinghurst
New Contributor III
Hi Kirill,
This is Service Request#:04468999.
The old machine was definitely upgraded (and downgraded) multiple times as I chased a Fortran/VS issue.  It has a Haswell CPU.  It can't run vtune with hardware sampling when Hyper-V was enabled, so I didn't use vtune after July.
Here is the output from 'emon -v'.  There is a diff below. The redirected version is missing the 'OS Processor <-> Physical/Logical Mapping' block
(c) 2019 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>cd "C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64"
C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64>.\emon -v
EMON Version .............. V11.14
Copyright(C) 1993-2019 Intel Corporation. All rights reserved.
Application Build Date: Nov 26 2019 at 11:43:58
SEP driver version: 5.14
total_number_of_processors  ...... 8
number_of_online_processors ...... 8
cpu_family ................ Intel(R) Xeon(R) E5/E7 v3 Processor code named Haswell
cpu_model ................. 63 (0x3f)
cpu_stepping .............. 2 (0x2)
L1 Data Cache ............. 32KB, 8-way, 64-byte line size
                            2 HW threads share this cache, No SW Init Required
L1 Code Cache ............. 32KB, 8-way, 64-byte line size
L2 Unified Cache .......... 256KB, 8-way, 64-byte line size
L3 Unified Cache .......... 10MB, 20-way, 64-byte line size
                            No SW Init Required
Data TLB .................. 4-way, 4K Pages, 64 entries
64-byte Prefetching
Device Type ............... Intel(R) Xeon(R) E5/E7 v3 Processor code named Haswell
EMON Database ............. haswell_server
number_of_selectors ....... 4
number_of_var_counters .... 4
number_of_fixed_ctrs....... 3
Fixed Counter Events:
counter 0 ................. INST_RETIRED.ANY
counter 1 ................. CPU_CLK_UNHALTED.THREAD
counter 2 ................. CPU_CLK_UNHALTED.REF_TSC
number of devices ......... 1
number_of_events .......... 578
Processor Features:
    (Thermal Throttling) (Enabled)
    (Hyper-Threading) (Enabled)
    (MLC Streamer Prefetching) (Enabled)
    (MLC Spatial Prefetching) (Enabled)
    (DCU Streamer Prefetching) (Enabled)
    (DCU IP Prefetching) (Enabled)
    (Number of Packages:    1)
    (Cores Per Package:    4)
    (Threads Per Package:  8)
    (Threads Per Core:      2)
RAM Features:
    (Package/Memory Controller/Channel)
        (0/0/0) (Total Number of Ranks on this Channel: 3)
                 (Dimm0 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
                 (Dimm1 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
                 (Dimm2 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
        (0/0/1) (Total Number of Ranks on this Channel: 3)
                 (Dimm1 Info: Empty)
                 (Dimm2 Info: Empty)
        (0/1/0) (Total Number of Ranks on this Channel: 3)
                 (Dimm0 Info: Empty)
                 (Dimm1 Info: Empty)
                 (Dimm2 Info: Empty)
        (0/1/1) (Total Number of Ranks on this Channel: 3)
                 (Dimm0 Info: Empty)
                 (Dimm1 Info: Empty)
                 (Dimm2 Info: Empty)
QPI Link Features:
        Package 0 :
TSC Freq .................. 3500.00 MHz
CPU Freq (detected) ....... 3491.00 MHz
UFS Freq (limit) .......... 3000.00 MHz
MAX TURBO RATIO (limit)
1C .......... 3600.00 MHz
2C .......... 3600.00 MHz
3C .......... 3600.00 MHz
4C .......... 3600.00 MHz
5C .......... 3600.00 MHz
6C .......... 3600.00 MHz
7C .......... 3600.00 MHz
8C .......... 3600.00 MHz
9C .......... 3600.00 MHz
10C ......... 3600.00 MHz
11C ......... 3600.00 MHz
12C ......... 3600.00 MHz
13C ......... 3600.00 MHz
14C ......... 3600.00 MHz
15C ......... 3600.00 MHz
16C ......... 3600.00 MHz
17C ......... 3600.00 MHz
18C ......... 3600.00 MHz
          OS Processor    Phys. Package       Core      Logical Processor
                0               0               0               0
                1               0               0               1
                2               0               1               0
                3               0               1               1
                4               0               2               0
                5               0               2               1
                6               0               3               0
                7               0               3               1
C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64>.\emon -v > C:\temp\emon.txt
C:\Program Files (x86)\IntelSWTools\VTune Profiler 2020\bin64>type C:\temp\emon.txt
                            No SW Init Required
64-byte Prefetching
Processor Features:
RAM Features:
                 (Dimm1 Info: Empty)
                 (Dimm2 Info: Empty)
                 (Dimm0 Info: Empty)
                 (Dimm1 Info: Empty)
                 (Dimm2 Info: Empty)
                 (Dimm0 Info: Empty)
                 (Dimm1 Info: Empty)
                 (Dimm2 Info: Empty)
QPI Link Features:
        Package 0 :
The 'OS Processor <-> Physical/Logical Mapping' block is definitely missing from the redirected output.  The other diffs seem to be trailing whitespace that wasn't copied from the cmd window.
$ diff -u emon-cl.txt emon-redirect.txt
--- emon-cl.txt 2020-01-10 09:17:15.022888800 +1100
+++ emon-redirect.txt   2020-01-10 09:13:52.537519500 +1100
@@ -1,7 +1,7 @@
-EMON Version .............. V11.14
+EMON Version .............. V11.14
-SEP driver version: 5.14
+SEP driver version: 5.14
@@ -45,25 +45,25 @@
 RAM Features:
-        (0/0/0) (Total Number of Ranks on this Channel: 3)
-                 (Dimm0 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
-                 (Dimm1 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
-                 (Dimm2 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
-        (0/0/1) (Total Number of Ranks on this Channel: 3)
-                 (Dimm1 Info: Empty)
-                 (Dimm2 Info: Empty)
-        (0/1/0) (Total Number of Ranks on this Channel: 3)
-                 (Dimm0 Info: Empty)
-        (0/1/1) (Total Number of Ranks on this Channel: 3)
+       (0/0/0) (Total Number of Ranks on this Channel: 3)
+                (Dimm0 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
+                (Dimm1 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
+                (Dimm2 Info: Capacity = 8 GB, Data Width = 64, Form Factor = DIMM, Memory Type = Synchronous, Speed = 2133MHz)
+       (0/0/1) (Total Number of Ranks on this Channel: 3)
+                (Dimm1 Info: Empty)
+                (Dimm2 Info: Empty)
+       (0/1/0) (Total Number of Ranks on this Channel: 3)
+                (Dimm0 Info: Empty)
+       (0/1/1) (Total Number of Ranks on this Channel: 3)
 QPI Link Features:
-        Package 0 :
+       Package 0 :
@@ -90,17 +90,3 @@
-                   OS Processor <-> Physical/Logical Mapping
-          OS Processor    Phys. Package       Core      Logical Processor
-                0               0               0               0
-                1               0               0               1
-                2               0               1               0
-                3               0               1               1
-                4               0               2               0
-                5               0               2               1
-                6               0               3               0
-                7               0               3               1
Kirill_U_Intel
Hi, David.
Could you try to make your experiment with direct stdout call and file redirection for attached binaries? and provide output here?
sep_orig.exe
sep_no.exe
sep_full.exe
Thanks, Kirill
David_Billinghurst
New Contributor III
Kirill,
Output attached.  You are definitely on to something.  I have attached output from both Haswell and Skylark machines.
beehive / Haswell
C:\Temp\sep>
C:\Temp\sep>.\sep_orig -version
Sampling Enabling Product version: 5.14  built on Jan 10 2020 13:28:06
Platform type: 99
PMU: haswell_server
C:\Temp\sep>.\sep_orig -version > sep_orig.txt
C:\Temp\sep>type sep_orig.txt
C:\Temp\sep>.\sep_no -version
Platform type: 99
PMU: haswell_server
C:\Temp\sep>.\sep_no -version > sep_no.txt
C:\Temp\sep>type sep_no.txt
C:\Temp\sep>.\sep_full -version
Platform type: 99
PMU: haswell_server
C:\Temp\sep>.\sep_full -version > sep_full.txt
C:\Temp\sep>type sep_full.txt
Platform type: 99
PMU: haswell_server
draco / Skylark
C:\temp\sep>.\sep_orig -version
SEP Driver Version: 5.9
Platform type: 111
PMU: skylake_server
C:\temp\sep>.\sep_orig -version > sep_orig.txt
C:\temp\sep>type sep_orig.txt
C:\temp\sep>.\sep_no -version
Platform type: 111
PMU: skylake_server
C:\temp\sep>.\sep_no -version > sep_no.txt
C:\temp\sep>type sep_no.txt
C:\temp\sep>.\sep_full -version
Platform type: 111
PMU: skylake_server
C:\temp\sep>.\sep_full -version > sep_full.txt
C:\temp\sep>type sep_full.txt
Platform type: 111
PMU: skylake_server
Kirill_U_Intel
Kirill,
beehive / Haswell
C:\Temp\sep>
Platform type: 99
PMU: haswell_server
Platform type: 99
PMU: haswell_server
Platform type: 99
PMU: haswell_server
Platform type: 99
PMU: haswell_server
draco / Skylark
Platform type: 111
PMU: skylake_server
Platform type: 111
PMU: skylake_server
Platform type: 111
PMU: skylake_server
Platform type: 111
PMU: skylake_server
Great.
Could I ask you about the last experiment with attached sep_no_buf.exe?
Kirill
David_Billinghurst
New Contributor III
Results below.  No problem to run more tests if required.  I am keep to get this resolved.
beehive / Haswell
C:\Temp\sep>.\sep_no_buf -version
Sampling Enabling Product version: 5.14  built on Jan 13 2020 12:29:03
Platform type: 99
PMU: haswell_server
C:\Temp\sep>.\sep_no_buf -version > sep_no_buf.txt
C:\Temp\sep>type sep_no_buf.txt
Platform type: 99
PMU: haswell_server
draco / Skylark
C:\temp\sep>.\sep_no_buf -version
Platform type: 111
PMU: skylake_server
C:\temp\sep>.\sep_no_buf -version > sep_no_buf.txt
C:\temp\sep>type sep_no_buf.txt
Platform type: 111
PMU: skylake_server
Kirill_U_Intel
David, thank you very much for your efforts. We have needed information to fix that.
David_Billinghurst
New Contributor III
Thank you.
David_Billinghurst
New Contributor III
Similar problem at https://software.intel.com/en-us/forums/vtune/topic/831408
David_Billinghurst
New Contributor III
Hi Kirill,
I received a new sep.exe from Intel support.  VTune 2020 now works for hotspot analysis, and it has already found some opportunities for improvement.  Excellent.  Thank you for your assistance.
JananiC_Intel
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please post a new question.
Janani Chandran
