Is there anyway we can profile mobile application on both Android and IOS using Vtune. If yes can someone suggest the process and share if any tutorial or document which i can refer.
Good day to you.
Thank you for posting in Intel communities.
Intel® VTune profiler is not directly available on Android or iOS but, Intel® VTune™ Profiler can be installed on the Windows*, Linux,* or macOS* host to analyze code performance on a remote Android* system.
You can use the Android Device (ADB) option under the where section in configure analysis as given below:
You can also refer to this link for more information :
VTune Profiling on iOS is not supported as of now.
If this resolves your issue, make sure to accept this as a solution.
This would help others with similar issue. Thank you!
Thanks and Regards,
Diya
We have not heard back from you.
Is your issue resolved with the above solution?
Thanks and Regards,
Diya
Good day to you.
We assume that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Diya Nandy
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
