Analyzers
5253 Discussions
vtune get no result with unlimited stack size
roch
vtune:2023.0.0
sys:centos 9.0
command:
vtune -collect hotspots -knob sampling-mode=hw -knob enable-stack-collection -knob stack-size=0 (programe)
vtune sepdk driver installed.
DiyaN_Intel
There seems to be a small error in the command that you are using to perform the analysis.
The correct format for specifying the knobs along with the remaining VTune command is:
-knob KnobName=KnobValue
The corrected command is :
vtune -collect hotspots -knob sampling-mode=hw -knob enable-stack-collection=true -knob stack-size=0 (program)
Please do note that the knob stack-size=0 is not required for the command since by default VTune is designed to use unlimited stack size.
Refer: https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/command-line-interface/command-line-interface-reference/stack-size.html
If this resolves your issue, make sure to accept this as a solution.
This would help others with similar issue. Thank you!
Thanks and Regards,
Diya
DiyaN_Intel
Good day to you.
We have not heard back from you.
Is your issue resolved with the above solution?
Thanks and Regards,
Diya
DiyaN_Intel
Good day to you.
We assume that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Diya Nandy
