Analyzers
5339 Discussions
Why VTune cannot show function name?
CRquantum
I use windows 10 1909. I installed the latest Intel OneAPI, 2021.3 I believe, and it integrates with Visual studio 2017.
I run my Fortran code with VTune. I enabled debug information-> full, turned on trace back.
In VTune, I enabled the following settings, and I use administer mode in visual studio,
However, the problem is, after running VTune, I just cannot see the function name, see below,
CRquantum_2-1631679386635.pngCRquantum_2-1631679386635.pngCRquantum_3-1631679409013.pngCRquantum_3-1631679409013.png
I wonder, how to show function names? Because without function names being displayed, VTune's result is useless.
Also, I have some errors in the collection log, how to fix? See below.  Thank you very much indeed!
Denis_M_Intel
It looks like it is enough to enable Yes(DEBUG) option for Fortran projects and /Zi option is not exposed in VS dialogs. This help topic should be updated with Fortran -specific information.
Denis_M_Intel
1. Do you have stochastic_RK.pdb file generated for your application stochastic_RK.exe? What compiler and what build options are used? /Zi and /DEBUG:FULL are expected - see more details in Debug Information for Windows Application Binaries (intel.com)
Can you reproduce it on some small "hello world" application and attach .exe and .pdb binary files here?
2. These warning messages on the screenshot are about system libraries.  You can ignore them if you are not interested in profiling system libraries. It is possible to download .PDBs for Windows libraries via Microsoft Symbol Server - more details: Debug Information for System Libraries (intel.com)
CRquantum
Thank you very much!
It turns out that I did not do
Now as I choose Yes(DEBUG), it can show function name now.
Here I attached the exe and pdb file.
The problem seems solved.
By the way, one more thing. In the link you provided,
https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/set-up-analysis-target/windows-targets/debug-information-for-windows-application-binaries.html
I see that,
However, I am using Intel OneAPI + visual studio 2017, it is Fortran.
However, I did not find 'Debug Information Format' field and Program Database.
CRquantum_2-1631747412965.pngCRquantum_2-1631747412965.pngCRquantum_3-1631747432357.pngCRquantum_3-1631747432357.png
 I wonder, for Fortran is there 'Debug Information Format' field and 'Program Database' option?
Denis_M_Intel
JananiC_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
