Analyzers
5338 Discussions
undefined reference to 'dlerror' when using Intel ITTAPI
JayJ
Hello everyone... I feel this is a straightforward problem, but I have been a bit stuck on fixing this problem.
I am following this link to profile performance anomaly:
https://software.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/configuration-recipes/profiling-performance-anomalies.html
But having a bit of a hard time getting the program to compile.
Code is straightforward, just simply trying to create PT region by following the above tutorial:
However, upon trying to compile it using the below command:
Looking like I am having some issue with the linking/loading phase that is not related to installation?
I have also tried manually installing the API library from https://github.com/intel/ittapi and do things manually, but no luck, so I am asking for help...
VTune Profiler itself works properly; I have run the vtune-self-checker.sh and used vtune-gui to see whether I could do a simple analysis such as a hotspot.
Thank you in advance, and I would appreciate any suggestions.
JananiC_Intel
Thanks for posting in Intel forums.
Try the below command to compile your itt code.
icpc -g <cpp file> -I/opt/intel/oneapi/vtune/latest/sdk/include /opt/intel/oneapi/vtune/latest/sdk/lib64/libittnotify.a -lpthread -o <executable_name>
The above command is for cpp code.You can replace icpc with icc for c language code and these icc and icpc are classic compilers which are included in Intel HPC toolkit.
You can also refer the below itt documentation for other configurations.
https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/api-support/instrumentation-and-tracing-technology-apis/basic-usage-and-configuration/attaching-itt-apis-to-a-launched-application.html
Janani Chandran
JananiC_Intel
Janani Chandran
JananiC_Intel
Is your issue resolved? Do you have any update?
Janani Chandran
JayJ
Dear JananiC,
I sincerely apologize for the late response; your suggestion of using the HPC toolkit compiler worked! I didn't know such a compiler existed, so I'm glad I asked for help, or otherwise, I wouldn't have been able to solve it.
Thank you for your help,
Kind regards.
JananiC_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
