Analyzers
5261 Discussions
problème enregistrement : locale::facet::_S_create_c_locale name not valid
theow13
bonjour,
je suis novice sur intel amplifier.
J'utilise la ligne de commande pour collecter mes données : amplxe-cl -q -collect hotspots -r NOM -data-limit=4000 --
En lançant mon programme, j'ai la ligne d'erreur :
amplxe: Error: 0x40000003 (Unexpected internal error / invalid state) -- locale::facet::_S_create_c_locale name not valid
avec
srun: error: n1928: task 19: Exited with exit code 2
srun: Terminating job step 12140471.0
Je ne peux pas ouvrir le fichier que je créé avec la commande amplxe-gui par la suite.
Avez-vous des idées de la cause ?
Merci d'avance !
Theo
RahulU_Intel
Thank you for posting your question, however this is an English-only forum. I have translated your question and here is what resulted. Is this the question you were intending to ask?
"registration problem: locale :: facet :: _ s_create_c_locale name not valid
i am new to intel amplifier.
i am using the command line to collect my data: amplxe-cl -q -collect hotspots -r name -data-limit = 4000 -
when launching my program, i got the error line:
amplxe: error: 0x40000003 (unexpected internal error / invalid state) - locale :: facet :: _ s_create_c_locale name not valid
with
srun: error: n1928: task 19: exited with exit code 2
srun: terminating job step 12140471.0
  i cannot open the file i created with the amplxe-gui command afterwards.
do you have any ideas for the cause?
thanks in advance!
follow"
theow13
ok, thank you for the answer.
Yes it is my question, and maybe i can give you more informations, I use intel/17.2 (Intel Compiler Suite) and vtune/2017.4.0.518798 (profiler).
Theo
RahulU_Intel
Thanks for the immediate response. We looked into your case. As you have mentioned your Vtune version in your previous reply ((vtune/2017.4.0.518798 (profiler)) you are using the older version of VTune. We are not able to reproduce the issue using the latest vtune (VTune 2021.5). We suggest you to install the latest version of VTune from the below link and try the same command and let us know if you face the same issue again. If you are using Vtune as standalone or with oneapi, from the below links you can choose either one according to your usage.
After installing the latest vtune, you could use the below command:
vtune -q -collect hotspots -result-dir <result directory> <target appilcation directory> -data-limit = 4000 -
To know more about different vtune commands you can refer this link:
https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/command-line-interface/command-syntax.html
For downloading latest version of oneAPI:
https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit/download.html
For downloading latest standalone version of VTune:
https://software.intel.com/content/www/us/en/develop/articles/oneapi-standalone-components.html#vtune
If the issue still persists, please let us know.
Thanks and Regards
Rahul
RahulU_Intel
We haven't heard back anything from you. Could you please confirm if the issue is resolved.
theow13
Not yet, i will try to resolve my problem maybe the next week.
I get back to you as soon as I try.
Thanks you  for the answer !
RahulU_Intel
We haven't heard back from you. Did you get any chance to try out our suggestions. Could you please confirm if the issue is resolved.
Thanks and Regards
Rahul
RahulU_Intel
I haven't heard back from you. So I will close this case for now. If you have further any queries you can post a new question.
Thanks and Regards
Rahul
