Analyzers
advisor-annotate.h header file
newport_j
Is the header file, advisor-annotate.h, compatible with gcc?
Does it only work with Intel's compilers such as icc, etc or can it work witth gcc also?
Thanks in advance.
Newport_j
Ravi_V_Intel
Hello Newport_j. You can use advisor-annotate.h with gcc. Please let us know if you experience any difficulty using it with gcc or any other compiler. Intel Developer Support
