Analyzers
amplxe-cl can not stop
zhu__xuefeng
hi,
I'm using vtune_amplifier_2019_update4 to perf my code. My command is
amplxe-cl -collect threading -run-pass-thru=--no-altstack -target-pid=108
here is the output
amplxe: Warning: Function '_PyEval_EvalFrameDefault' can be analyzed incorrectly because it uses indirect branch instructions.
amplxe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: amplxe-cl -r /r000tr -command stop.
^Camplxe: Warning: Cannot stop posix timer: __NR_timer_settime() system call returned -1.
amplxe-cl can't stop by press CTRL-C or amplxe-cl -r /r001tr -command stop.
By the way,  'amplxe-cl -collect hotspots-run-pass-thru=--no-altstack -target-pid=108' can stop normally.
Is there any hint for me?
Vladimir_R_Intel
As I remember there can be a problem if your code is in some instrumented function on the moment of detach, i.e. the tool can wait when you leave from the instrumented function to gracefully end its job. And if you don't leave such a function it won't end too.
But this is only an assumption what can happen in this situation. To give an exact answer we need to debug this. Is it possible to send us a reproducer?
BR,
Vladimir
