Analyzers
5307 Discussions
collecting emon type counter data with VTune
DarvZ
I'm trying to collect system wide performance counter data (emon type data) with VTune.  I have had some luck with runss using the following command string:
/opt/intel/vtune_amplifier_xe/bin64/amplxe-runss -d 120 -event-config="INST_RETIRED.ANY","CPU_CLK_UNHALTED.THREAD","CPU_CLK_UNHALTED.REF_TSC","UOPS_ISSUED.ANY","UOPS_ISSUED.STALL_CYCLES","UOPS_ISSUED.CORE_STALL_CYCLES","L2_RQSTS.ALL_CODE_RD","ICACHE.MISSES","RESOURCE_STALLS.ANY","L2_RQSTS.CODE_RD_HIT","L2_RQSTS.CODE_RD_MISS","ITLB_MISSES.WALK_DURATION","IDQ.EMPTY" -event-mux -event-mux-trigger="CPU_CLK_UNHALTED.REF_TSC"
Unforntunately if I add the -count-emon option I get an error "Event counting is incompatible with event multiplexing".  Is there another option to collect multiple counter groups with very minimal overhead (no hotspot information) in one run?  I realize if break this up into multiple collection it will work, but I was looking from a way to collect mutiple groups of counters (similar to general exploration) in one run.
Another issue a ran into is -count-emon and -count seem to do the same thing.  I was expecting -count-emon to display the data by counter with the CPU by CPU information listed horizontally.  In both cases with -count or -count-emon I find the data to be list vertically by counter and CPU number.
I'm using vtune_amplifier_xe_2013_update12 with SUSE Linux system runing on i7-4770 based system.
Thanks in advance for your help.
Peter_W_Intel
It seems there is no luck to do runsa:
# amplxe-cl -collect-with runsa -knob event-config=INST_RETIRED.ANY,CPU_CLK_UNHALTED.THREAD,CPU_CLK_UNHALTED.REF_TSC,UOPS_ISSUED.ANY,UOPS_ISSUED.STALL_CYCLES,UOPS_ISSUED.CORE_STALL_CYCLES,L2_RQSTS.ALL_CODE_RD,ICACHE.MISSES,RESOURCE_STALLS.ANY,L2_RQSTS.CODE_RD_HIT,L2_RQSTS.CODE_RD_MISS,ITLB_MISSES.WALK_DURATION,IDQ.EMPTY -run-pass-thru=count-emon -- /bin/ls
amplxe: Error: Event counting is currently incompatible with event multiplexing.
Same thing when using amplxe-cl:
# amplxe-cl -no-allow-multiple-runs -collect advanced-hotspots -run-pass-thru=count-emon -- /bin/ls
ONLY using -allow-multiple-runs works (default option is -no-allow-mutiple-runs)
# amplxe-cl -allow-multiple-runs -collect advanced-hotspots -run-pass-thru=count-emon -- /bin/ls ; works
You can create a new analysis type on GUI to add/remove all events you like, then use this new analysis type instead of advanced-hotspots.
Peter_W_Intel
Even there was no problem when you ran above, there is no result (samples) for using sampling "counting" mode with multiplexing. It's better use:
amplxe-cl -no-allow-multiple-runs -collect advanced-hotspots -- /bin/ls ; multiplexing with regular sampling mode
As result, if use sampling collection in counting mode, multiplexing is not supported.
DarvZ
Thanks for all of you help Peter.  I was not aware of the -run-pass-thru option on amplxe-cl command.
