Analyzers
5250 Discussions
error in VTune 7.1: assertion failed in tbsana.cpp ln.766
michal_kowalski
Has anyone encountered this problem? I can run test app and it looks like sampling works but when it's done VTune cannot digest gathered data and shows assertion failed msg box (tbsana.cpp ln.766).
At that point I can do nothing useful. This happens in stand-alone VTune analyzer as well as in the integreted into VS.
Does VTune choke on Athlon? Ooops, sorry, did I say Athlon here? I meant compatible x86 CPU.
MK
magga
i've got the same problem!
magga
it happens during converting to mdb database... Call Graph doesn't work either.
David_A_Intel1
The list of supported processors is in the Release Notes. Non-Intel processors are not supported, since they may not have the necessary processor registers and settings.
