Analyzers
5342 Discussions
fatal error: advisor-annotate.h
liu_wei67
HI:
I encountered the problem of the advisor-annotate.h header file when using the advisor example on the official website.
1.Return to the Survey Report, right-click any data row in the top pane, and choose Edit Source
 to open the nqueens_serial.cppsource file in an editor.
2.Search for ADVISOR SUITABILITY EDIT and follow the directions in the sample code. Make four total edits:
- Uncomment //#include <advisor-annotate.h>
When I uncommented, the following error was reported when executing the command
>>> make 1_nqueens_serial
g++ -m64 nqueens_serial.cpp -o 1_nqueens_serial -O2 -g -I /include/ -ldl
nqueens_serial.cpp:74:10: fatal error: advisor-annotate.h: No such file or directory
74 | #include <advisor-annotate.h>
compilation terminated.
make: *** [Makefile:51: 1_nqueens_serial] Error 1
    Ruslan_M_Intel
    Try to edit the Makefile by changing 'ADVISOR_2018_DIR' to 'ADVISOR_2021_DIR'
    liu_wei67
    thanks, I have solved this problem.
    RahulU_Intel
    Thanks for posting in Intel communities. Glad to know that your issue is resolved. If you need any additional information, please submit a new question as this thread will no longer be monitored.
    Thanks and Regards
    Rahul
