Analyzers
5253 Discussions
generate a report via command line for "platform" informations.
Sven_L_
Hi there,
I'm using Intel Amplifier VTune for performance measurements of Java Applications. Is it possible to generate a report via command line like the "Platform" Tab in the UI? I need to know how many threads my programm use and how much time each thread uses for computation (CPU), Idling and synchronization. The "Platform" tab in the ui show most of the information, but i would like to generate a report via command line.
Sven
Peter_W_Intel
Platform view is graphic report for CPU usage / frequency on threads time by time, how can it output in text format?
You might use "amplxe-cl -R hotspots -group-by thread -r result" to know, in command line.
Peter_W_Intel
Sven_L_
Thank you Peter, works great. :)
