Analyzers
how to ???
cosas
i've hot XEON server and only shell access. I've installed vtune but... how to use? need i Xwin ? how do i uninstall? where are docs???
jeffrey-gallagher
Hey Cosas,
Docs are located:
/opt/intel/vtune/docs/
To get started, you might start at the GETTING STARTED manual:
/opt/intel/vtune/docs/getting_started/index.htm
Also, you might want to take a look at each of the following:
$ man vtl
$ man vtlec
$ man sampling
$ man callgraph
$ man 7source # which is the same as
$ man code
$ man ActivityController
You don't need IXI to run our graphical product (vtlec); and, when you install you also get a command line version (vtl).
The uninstall binary is in the/opt/intel/vtune/bin directory.
Most of this info is in the Release Notes, which can be very hard to find if you didn't note the installation directory during install.
cheers
jdg
Message Edited by jdgallag on 04-04-2005 07:38 AM
jeffrey-gallagher
Hey Cosas,
Please do your best to report back and let us here at the forum know if any of those suggestions helped, or not.
cheers
jdg
