Analyzers
5253 Discussions
invalid memory access by Fortran intrinsic date_and_time
Alexis_R_
Apologies if this is FAQ, but the following code when compiled with -g and -O0 has a "Invalid memory access problem" on line 4 - is there an explanation for this? I think the Fortran is kosher, and this is an intrinsic function.
[fortran]program test
implicit none
integer :: date_values(8)
call date_and_time(values=date_values)
print '(a,8(i0,x))', 'date values = ', date_values
end program test[/fortran]
This is with composer XE update 3 and inspector XE update 2, under Fedora 13. The Memory Error Analysis preset I used was "Locate Memory Problems".
Similarly, the inspector finds an "Invalid memory access problem" on line 6 of this test program:
implicit none
character(len=4), parameter :: var_name = 'TERM'
character(len=11) :: var_value
integer :: ierr
call get_environment_variable(var_name,value=var_value,status=ierr)
if (ierr .ne. 0) then
print *, 'error when getting env var: ', ierr
endif
print '(4a)', 'environment variable ', var_name, ' = ', trim(adjustl(var_value))
Peter_W_Intel
The problem has been solved in latest Update 3 - please download new package from Intel Registration Center, Download Site.
Regards, Peter
Peter_W_Intel
I cannot reproduce this problem. Save test case 1 to test_insp.f90, test case 2 to test_insp1.f90
[root@NHM02 problem_report]# ifort --version
ifort (IFORT) 12.0.3 20110309
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
[root@NHM02 problem_report]# ifort -g test_insp.f90 -o test_insp
[root@NHM02 problem_report]# ifort -g test_insp1.f90 -o test_insp1
[root@NHM02 problem_report]# inspxe-cl -version
Intel Inspector XE 2011 Update 1 (build 131372) Command Line tool
Copyright (C) 2009-2010 Intel Corporation. All rights reserved.
[root@NHM02 problem_report]# inspxe-cl -collect mi3 -- ./test_insp
Used suppression file(s): []
date values = 2011 4 25 480 15 38 44 454
0 new problem(s) found
[root@NHM02 problem_report]# inspxe-cl -collect mi3 -- ./test_insp1
environment variable TERM = xterm
Regards, Peter
Alexis_R_
Insteresting... As you will see below, with exactly the same commands and the same versions of Composer & Inspector, I get different results. Please advise what steps to take next to debug this.
[bash]$ ifort --version
$ ifort -g test_date.f90 -o test_date
$ inspxe-cl -version
$ inspxe-cl -collect mi3 -- ./test_date
date values = 2011 4 25 -240 9 47 22 60
1 new problem(s) found
    1 Invalid memory access problem(s) detected
$ ifort -g test_env.f90 -o test_env
$ inspxe-cl -collect mi3 -- ./test_env
2 new problem(s) found
    1 Invalid partial memory access problem(s) detected
[/bash]
Alexis_R_
Peter,
Any news on this?
On my part I have found that running Inspector as root on the same files gives different results, with only the "Invalid partial memory access" error in the test_env case. In the test_date case though, I got exactly the same output as above when running as root.
It would be good to get some feedback on this.
Peter_W_Intel
Regards, Peter
