Analyzers
5260 Discussions
<Outside any known module>, Vtune Amplifier Error
Youngil_K_
Hi, everyone
Currently I'm using VTune analyzer in linux system to profiling java code.
I generated report by attaching it to the running process.
However, in top-down tree, I usually can see [Outside any known module] which took certain amount of time.
When I click it, I couldn't see any thing.
The strange thing is that sometime it can generate proper top-down report.
When vtune can generate proper report, trace file is usually about 500MB
On the other hands, when it can't generate, trace file is just about 5MB
There are plenty of opinion that it is because of "code on the fly".
So, I tried this steps after turning off the JIT option in jdk.
Ofcourse, I ran it under root.
But it doesn't work well.
My Ubutu version is 14.04.1 LTS
Please help me!!
Any kind of probable ideas may be helpful
David_A_Intel1
So, two things I noticed:
  1. "-mrte-mode=native" - this limits collection to *native* code.  You should omit this option so that managed code can be profiled.
  2. In reviewing release notes, I see that we added support for attaching to Java on Linux* for hardware-based sampling, only, in Update 4 of the 2013 release.  Therefore, change your collect option to "-collect advanced-hotspots" and try again.
Hope that helps.
Peter_W_Intel
Did you use supported JDK/JRE? Please see release notes. You need to use javac to build with "-g" option.
What is command line you used amplxe-cl? VTune Amplifier XE version?
Youngil_K_
Thank you for replying my question.
1. Did you use supported JDK/JRE?
   When I typed following command
    => java -version
   It shows like following
    => java version "1.7.0_67"
      Java(TM) SE Runtime Environment (build 1.7.0_67-b01)
      Java HotSpot(TM) 64-Bit Server VM (build 24,65-b04, mixed mode)
2. javac to build with "-g" option.
   When I compiled *.java file, I used command like following:
   javac -g javatest.java
   We are using VTune GUI in linux system.
   The command that GUI make automatically is like following:
  => /opt/intel/vtune_amplifier_xe_2015.1.0.367959/bin64/amplxe-cl -collect hotspots -knob sampling-interval=1 -strategy=:trace:trace -mrte-mode=native --search-dir sym:p=/home/seungdo/workspace --target-process java
    And the result is like following
        Thank you for your help!!!!!!!!!!
David_A_Intel1
Hope that helps.
Youngil_K_
Thank you very much!!
But I have one more problem.
When I profiling with your advice, I have <unknown outside> message again like following
I think it is because that VTune cannot profile child process well.
When we profile, we are using attach to process method with PID information.
And when we profile with PID of child process that original process made or when we profile the process that doesn't make child process,
it could profile well without showing that error message.
The project properties related to the child process profiling is like following:
Really appreciate for you help.
Best Regards
Youngil_K_
To help your understanding I would like to add some more information about my problem
I guessed that maybe this <Unknown> problem is because of child process.
When I checked java process using Java VisualVM, it shows like following:
And when I give some job to daemon process (PID 7056), it generate child process like following:
I am sure that <unknown> error is because of this child process
Bernard
Valued Contributor I
Thank you for your help!>>>
Can VTune resolve parent proces? In your case  proces PID 7056.
David_A_Intel1
@Youngil:
I think the problem is that when you attach to a process, any child processes already created by that process are unknown to the VTune Amplifier.  VTune Amplifier inserts hooks to recognize when a new process is created, but because they were already created *prior* to VTune Amplifier attaching the process, it has no way of knowing about the child processes.
Are you trying to profile a Java app started by Apache?  A technique we used many years ago was to modify the script that Apache uses to start the Java app and insert the VTune Amplifier command line, so that Apache starts VTune Amplifier and VTune Amplifier starts your Java app.  That way, VTune Amplifier will know all about your application, including child processes. ;)  And, if you don't want to collect all that profiling data about your app's start up, use the -start-paused option and enabling profiling once you are ready.
Peter_W_Intel
I wrote the article about profiling Java from Apache-Tomcat, hope it helps.
Karolina_S_Intel
Check this page:
https://software.intel.com/en-us/vtune-help-enabling-linux-kernel-analysis
Make sure you set this before running the trace:
sysctl -w kernel.kptr_restrict=0
