Analyzers
multithreaded application | waits and locks analysis
Mourad_B_2
I am analyzing a multithreaded application with one main thread and 100 threads-child.
I am trying to get the waitandlocks. when I am running this command line:
./amplxe-cl -collect locksandwaits -target-duration-type=medium -follow-child  --target-pid "pid"
I have this error:
amplxe: Error: Assertion '(blocked == tpss_tls_op_err_ok)' failed.[ASSERTION CONTEXT][CONTEXT END]. Please contact the technical support.
amplxe: Error: Assertion 'head.sp >= sp' failed.[ASSERTION CONTEXT]head.sp = 0xfec6c286, sp = 0x7f3e8e7f
any ideas to fix it?
Mourad
Vitaly_S_Intel
> any other way to do locks and waits analysis without to attach the process?
Sure, try the following command:
amplxe-cl -collect locksandwaits -- <path to application executable and its command line>
It'll start your application. Probably that way it won't crash.
Anyway, it would be good to know if crash related to attach mode only.
Vitaly_S_Intel
Can you please also tell the result of the following command:
amplxe-cl -collect hotspots -duration 10 -target-pid <PID>
Does it cause this issue or not?
Mourad_B_2
the hotspots analysis is working well. thanks for your message.
--mb
Mourad_B_2
--mb
