Analyzers
5253 Discussions
new to vtune, 2 questions.
odedf
I am new to vtune. (Just installed the 8.0 version.)
Two very different questions.
1. Was able to run the first use wizard.
I would like to know the percentage of the time each function is active,
i.e. if the program is composed of a main that calls function f that is active 95% of the time, I would like to view the result as 100% main + 95% f rather then 5% main + 95% f. How is it done?
2. Is there a document describing a recommended a methodology to use the v-tune in order to optimizea codes performance?
Oded.
David_A_Intel1
Hi Oded:
1. Actually, in the normal sampling views (i.e., not the Summary view generated by the first-use wizard), the results are displayed as percent of module, so if you use the Sampling wizard, I think you will see what you want.
2. On the Welcome page, select Help. You should see a Tuning Methodologies entry under the VTune Performance Analyzer Help on the left side, as well as a link toThe Tuning Metholdogy on the main help page.
Message Edited by DaveA on 01-03-2006 04:52 PM
