Analyzers
5335 Discussions
problem with exe controller?
Judith_W_Intel
I get this error when trying to create a callgraph
for the compiler. If I remove some of the arguments
to mcpcom the error goes away.
vtl activity -c callgraph -app mcpcom,-p,--bool,timing.cpp -moi mcpcom run
VTune Performance Analyzer 1.0 for Linux*
Copyright (C) 2000-2002 Intel Corporation. All rights reserved.
The Activity is running.
The Activity failed to stop callgraph collector,
because there are no valid exe controllers associated with the collector.
Unable to run the activity because an appropriate EXE controller could not be created. This is probably either because a specified remote system could not be found or because a specified remote system is not properly configured.
Daniel_B_Intel2
hi,
I admit, the error message is indeed misleading
The real problem seems to be is in a way you pass the parameters.
The correct way is: (vtl -help)
[-app | -app-to-launch [,[,]]]
so in case you have to pass multiple parameters use:
vtl activity Regular -c callgraph -app /bin/ls,"-l -R -F -a" -moi /bin/ls run
(no , separates different parameters)
In you example I guess the correct syntax will be:
vtl activity -c callgraph -app mcpcom,"-p --bool timing.cpp" -moi mcpcom run
Does it help?
-Daniel
Judith_W_Intel
Well that helped me get started but now I get
an internal error:
n=800 timing.cpp" -moi mcpcom run
Wed Feb 26 17:49:59 2003 Static instrumentation started
Discovery Summary:
Found 18775 procedures. Fail to instrument 3 of them.
Found 1 additional functions. Fail to instrument 0 of them.
Wed Feb 26 17:50:30 2003 All functions instrumentation of module mcpcom was successful.
Wed Feb 26 17:50:30 2003 None instrumentation of module ld-2.2.4.so was skipped.
Wed Feb 26 17:50:30 2003 Exports instrumentation of module libc-2.2.4.so was skipped.
Wed Feb 26 17:50:30 2003 All functions instrumentation of module libm-2.2.4.so was skipped.
Wed Feb 26 17:50:30 2003 Static instrumentation done
Wed Feb 26 17:50:33 2003 Data collection started...
Intel C++ Compiler for 32-bit applications, Version 8.0 Pre-Beta Build x
Built Feb 26 2003 16:14:38 by jward4 on nht6011.spt.intel.com in /home/nsl/jward4/cmplr/dev_cfe/dev
Copyright (C) 1985-2003 Intel Corporation. All rights reserved.
(0): internal error: #0_3645: catch entry list and handler info list differ in length (shared/ip/ipo_inl.c, line 3645)
Judith_W_Intel
Never mind my last reply. It looks like
the internal error is coming from the compiler.
Aaron_L_Intel
Hi Judy,
BTW, thanks for posting this one. The way in which vtl was invoked in the initial post should have been interpreted as a syntax error by vtl--however, the input was accepted and resulted in the weird message having to do with EXE Controllers.
This has been fixed, and the fix will be available in the next release of the product.
Aaron Levinson
