Analyzers
5341 Discussions
regarding intel vtune-gui command
neutron
Naive question wrt vtune installation..
I have downloaded the latest version of intel vtune and installed it on a server. I was able to install the software using install_GUI.sh script which opens up gui. After installation, i am able to see vtune cli and vtune gui version binaries. But, i am unable to see the application gui once i give the command ./vtune-gui. There is no error reported on the screen..but no gui comes. up. My X11 forwarding is working fine as on running xclock or install_GUI.sh script , i am able to see the gui.
The other binary vtune works fine. Can you please point out where to check for error logs or more verbose information to cross-check this issue. Or if you already know the workaround for this, kindly suggest.
ArunJ_Intel
Hey neutron,
Previously I had faced an issue with X11 forwarding  not working  for  vtune . But I had the an error message as below
./vtune-gui: error while loading shared libraries: libX11-xcb.so.1: cannot open shared object file: No such file or directory.
I could solve this by installing the packages mentioned in the below link.
https://medium.com/@ssmak/how-to-fix-puppetteer-error-while-loading-shared-libraries-libx11-xcb-so-1-c1918b75acc3
However your issue in the case might not be exactly same, as you dont have any error messages. I dont use vtune x11 forwarding very much with vtune as I find X11 forwarding to be slower compared to port forwarding.
A solution/workaround that I can provide for your current problem is to use vtune webserver. This launches vtune in a port and the port can be forwarded and easily opened on your host machine. Please find below information on how to use vtune webserver.
https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/launch/web-server-ui.html#web-server-ui
Hope this helps
Arun Jose
ArunJ_Intel
Hey neutron,
Hope this helps
Arun Jose
ArunJ_Intel
Hi Neutron,
Have you tried out the solution provided. Does that help in solving your issue?
Arun
neutron
Hi Arun,
Thank you, using vtune webserver mode resolved the issue.
ArunJ_Intel
Thanks Neutron for the confirmation we will be no longer monitoring this issue. Please feel free to raise a new thread for further issues
