Analyzers
5275 Discussions
report generation, Error: Error 0x40000024 (Reporter error)
yilmazer
I am doing lightweight-hotspots analysis with vtune amplifier xe. I am getting this error, Error 0x40000024 (reporter error)- results directory does not contain CPU samples. If I look at the rresults directory I see there is 105MB of data there. Can you please help me solve this problem.
Thank you!
Peter_W_Intel
Usually when you ran your application shortly, and didn't specify "-duration n" - so collector haven't collected any sample.
Can you generate data by using below?
[root@NHM02 test]# amplxe-cl -collect lightweight-hotspots -duration 5
[root@NHM02 test]# amplxe-cl -report hotspots
-peter
yilmazer
If I ran it without givin an applicationname as a parameter to collect system wide data then yes I can generate report.
> ample-cl -collect lightweight-hotspot -duration 5
However if I run it with -duration 5 and withmy benchmark, I cannot generate report. Actually I am running cpu2006 benchmarks and they are running longer. And I have been able to generate data/reports with some of the benchmarks in cpu2006but couldn't get reports with some of them.
Thank you very much for your responce.
Mark_D_Intel
Check that there is a file with a tb6 suffix present in the /data.0 directory.
If so, it appears to be a problem with the data loader.
Be sure to use the lastest version (Update 2) of Amplifier XE.
What hardware/OS are you using?
yilmazer
Yes, I do have a data file with tb6 suffix with a size of around 33MB.
I am running it on Intel Core i7 CPU with 2.6.16.60 Linux kernel.
The version of vtune is- 2011 Update 1 (build 128765). I guess I need to update to (Update 2).
So, hopefully this problem goes away with the newer version.
Thanks for the help.
yilmazer
It turned out amplifier xe is not being able to associate the performance data to the application. Data related to the shown as attributed to "Other64+".
What do you think what could be the problem and can you suggest any solution?
Thank you very much!
Peter_W_Intel
Maybe your data is old (raw data??), and you rebuilt the application. So please do performance analysis again.
Regards, Peter
