hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Analyzers
5184 Discussões
source/assembly code for the selected object is not available
hui_yuan
Novato
603 Visualizações
I encountered a problem when using Intel vtune profiler.
As shown in the figure below, I performed hot spot analysis on the program, but no results were displayed in the end. The error prompt is as shown in Figure 2.
Has anyone encountered a similar problem?
6 Respostas
yuzhang3_intel
Moderador
592 Visualizações
Please attach the screenshot of the function you selected in the 'Bottom-up' tab.
hui_yuan
Novato
529 Visualizações
no data to show
yuzhang3_intel
Moderador
522 Visualizações
Could you share the VTune data with me? Let me check. The folder name should be r000hs, and can you provide the VTune version and platform information as well?
hui_yuan
Novato
489 Visualizações
data file attached.
The version is VTune profiler 2024.2.1.
The platform is windows 11
yuzhang3_intel
Moderador
483 Visualizações
Please specify a new working path and remove the special characters, like ® and ™. Try again.
D:\projects\PG_MHT\CAE-master\Code\main\Intel® VTune™ Profiler Results\PGThermoStr
hui_yuan
Novato
461 Visualizações
problem solved. Thank you very much.
非常感谢!
Responder
