Analyzers
source viewing problem with Vtune GUI
MARK_A_2
I am only able to view assembly in the Vtune GUI. I see the assembly but the "Source" button is grayed out and not active.  I compile with
-g -O3 -fp-model fast -xMIC-AVX512 -qopt-report=5 -dynamic --vtune
I run with
 amplxe-cl -no-auto-finalize -collect hotspots -r res_dir
I finalize with
amplxe-cl -finalize -search-dir /global/u2/m/madams/petsc/arch-knl-opt64-ma64-simd/lib/ -source-search-dir /global/u2/m/madams/petsc/src/dm/impls/picell -source-search-dir . -search-dir . -source-search-dir /global/u2/m/madams/petsc/src/dm/dt/interface
The function that I want to view is in a c file in this ...dm/dt/interface directory.
Denis_M_Intel
Are there any warnings related to your application binary or symbol files in VTune finalization output?
Can you check with the addr2line Linux utility that first address of the function has source file and source line information?
MARK_A_2
amplxe: Using result path `/global/u2/m/madams/petsc/src/dm/impls/picell/examples/tutorial/res_dir.cc06'
amplxe: Executing actions 45 % Resolving module symbols
amplxe: Warning: Cannot locate file `/lib64/libc.so.6'.
amplxe: Warning: Cannot locate file `/usr/common/software/intel/compilers_and_libraries_2016.3.210/linux/mpi/intel64/lib/libmpi.so.12'.
amplxe: Warning: Cannot locate file `/usr/common/software/intel/compilers_and_libraries_2016.3.210/linux/mpi/intel64/lib/libmpifort.so.12'.
amplxe: Executing actions 45 % Resolving information for `libc.so.6'
amplxe: Warning: Cannot locate file `/usr/common/software/memkind/1.0.0/carl/gnu/lib/libmemkind.so'.
amplxe: Executing actions 45 % Resolving information for `libmpi.so.12'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/vtune_amplifier_xe_2016.3.0.463186/lib64/pinruntime/glibc/libc-2.3.4.so'.
amplxe: Executing actions 45 % Resolving information for `libc-2.3.4.so'
amplxe: Warning: Cannot locate file `/lib64/libpthread.so.0'.
amplxe: Executing actions 45 % Resolving information for `libpthread.so.0'
amplxe: Warning: Cannot locate file `/usr/common/software/numactl/2.0.11/carl/bin/numactl'.
amplxe: Executing actions 45 % Resolving information for `numactl'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/vtune_amplifier_xe_2016.3.0.463186/lib64/runtime/libittnotify_collector.so'.
amplxe: Executing actions 46 % Resolving information for `libittnotify_collecto
amplxe: Warning: Cannot locate file `/lib64/libdl.so.2'.
amplxe: Executing actions 46 % Resolving information for `libdl.so.2'
amplxe: Warning: Cannot locate file `/lib64/ld-linux-x86-64.so.2'.
amplxe: Executing actions 46 % Resolving information for `ld-linux-x86-64.so.2'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/vtune_amplifier_xe_2016.3.0.463186/lib64/pinruntime/libstdc++.so.6.0.13'.
amplxe: Executing actions 47 % Resolving information for `[vdso]'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/compilers_and_libraries_2016.3.210/linux/mkl/lib/intel64/libmkl_intel_lp64.so'.
amplxe: Executing actions 47 % Resolving information for `libmkl_intel_lp64.so'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/compilers_and_libraries_2016.3.210/linux/mkl/lib/intel64/libmkl_core.so'.
amplxe: Executing actions 48 % Resolving information for `libmkl_core.so'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/vtune_amplifier_xe_2016.3.0.463186/bin64/pinbin'.
amplxe: Executing actions 48 % Resolving information for `pinbin'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/compilers_and_libraries_2016.3.210/linux/mkl/lib/intel64/libmkl_sequential.so'.
amplxe: Executing actions 49 % Resolving information for `libmkl_sequential.so'
amplxe: Warning: Cannot locate file `/usr/common/software/numactl/2.0.11/carl/lib/libnuma.so.1'.
amplxe: Warning: Cannot locate file `/usr/common/software/intel/compilers_and_libraries_2016.3.210/linux/mkl/lib/intel64/libmkl_avx512_mic.so'.
amplxe: Executing actions 50 % Resolving information for `libmkl_avx512_mic.so'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/vtune_amplifier_xe_2016.3.0.463186/lib64/libtpsstool.so'.
amplxe: Executing actions 50 % Resolving information for `libtpsstool.so'
amplxe: Warning: Cannot locate file `/usr/common/software/intel/compilers_and_libraries_2016.3.210/linux/compiler/lib/intel64/libirc.so'.
amplxe: Executing actions 100 % done
My KNL is down but I will check this when I have a chance.
MARK_A_2
note, the listing that I showed before did not list the library (petsc) that I want to look into.
I took the address as listed in the GUI for a method in my source file ex2.c (ie, not in the library).
$ addr2line -a 0x40ff50 -e ex2.arch-knl-opt64-ma64-simd
0x000000000040ff50
Here is my compile and link line:
mpiicc -o ex2.o -c -fPIC  -wd1572 -g -O3 -fp-model fast -xMIC-AVX512 -qopt-report=5   -I/global/homes/m/madams/p        etsc/include -I/global/homes/m/madams/petsc/arch-knl-opt64-intel/include -I/usr/common/software/intel/compilers_        and_libraries_2016.3.210/linux/mpi/intel64/include    `pwd`/ex2.c
icc: remark #10397: optimization reports are generated in *.optrpt files in the output location
mpiicc -fPIC  -wd1572 -g -O3 -fp-model fast -xMIC-AVX512 -qopt-report=5  -o ex2.arch-knl-opt64-intel ex2.o ....
MARK_A_2
Oh Damn, it looks like I screwed up my makefiles and I am not actually using -g.
Sorry,
Mark
