Analyzers
vTune results
gray_heron
I'm doing a "hotspot analysis" of some processes on a container with VTune Profiler, but I'm not getting the results.
The tool is started from the command line, the process ID is specified, and the analysis is performed.
User mode sampling
Command: vtune -collect hotspots -duration=<sec> -knob sampling-mode=sw -target-pid <pid>
The tool does not end in the analysis of a specific process
(It does not return even if the time specified by the parameter is reached)
· Hardware event-based sampling
Command: vtune -collect hotspots -duration=<sec> -knob sampling-mode=hw -target-pid <pid>
"0x40000025 (Inapplicable report)" is output on the command line.
What could be the cause?
Regards.
RaeesaM_Intel
Thank you for reaching out to us. Could you please share the below details so that we can provide the necessary steps to profile inside container and help you with the error.
1) Clarify whether the vtune is in Host or the Container
2) The OS you are using
3) Version of VTune profiler
Please refer this link for profiling inside docker containers : https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/launch/containerization-support/run-from-container.html
https://www.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/configuration-recipes/profiling-in-docker-container.html
Raeesa
gray_heron
Thank you for your reply.
 Ubuntu 18.04.5 LTS
 Intel VTune Profiler 2021.5.0
Check the contents of the link.
Regards.
RaeesaM_Intel
We assume that you have the VTune installed in you Host and you need to profile some processes running on a target container. Please follow the below steps :
Command to start Target container:
  • docker run -p 80:8080 --rm -dti --name Target --network test --cap-add CAP_SYS_ADMIN <Image_name> bash
  • docker exec -it <containerID> bash
Install ssh and enable on the container:
  • apt-get update
  • apt-get install ssh
  • service ssh start
  • service ssh status
You will see that “ssh is running”
Enable password less ssh connection
To generate public rsa key for connection on host :
  •  ssh-keygen -t rsa (key will be saved in this path (/root/.ssh/id_rsa.pub))
copy the content inside "id_rsa.pub" to the Target : ~/.ssh/authorized_keys
In the Target container, create the following directory:
  • mkdir ~/.ssh
  • cd ~/.ssh
  • touch authorized_keys
 vi authorized_keys (Copy the contents of the "id_rsa.pub" file from the host and paste the content in this file)
On Host system
Now we need to get container ip address:
  • docker ps (copy container id and past in below command)
  • docker inspect -f '{{range.NetworkSettings.Networks}}{{.IPAddress}}{{end}}' container_id
after running above command we will get an ip eg: 172.17.0.2
How to verify that we can access the target container:
  • ping -c 3 <ip address of the container>(eg:172.17.0.2)
output looks like below:
PING 172.18.0.3 (172.18.0.3) 56(84) bytes of data.
64 bytes from 172.17.0.2.: icmp_seq=1 ttl=64 time=0.038 ms
64 bytes from 172.17.0.2: icmp_seq=2 ttl=64 time=0.043 ms
64 bytes from 172.17.0.2: icmp_seq=3 ttl=64 time=0.035 ms
--- 172.17.0.2 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2037ms
rtt min/avg/max/mdev = 0.035/0.038/0.043/0.007 ms
Profiling Python application using command line:
vtune -target-system ssh:root@<container ip address>(eg:172.17.0.2) -target-install-dir=/tmp/vtune_profiler -collect hotspots -app-working-dir /usr/bin --app-working-dir=/usr/bin -- /usr/bin/python3  <Path to the application in the Target container>
OR
Using VTune-GUI:
If you have GUI interface then you can use the command
>vtune-gui
the window will be opened and you can configure the analysis and get the results of process.
Also, try upgrading the VTune profiler to the latest version.
Please refer the below links for more details :
Hope this helps. Get back to us in case of any issues.
Raeesa
RaeesaM_Intel
Is your issue resolved? Please let us know the updates so that we can help you further if you have more issues.
Raeesa
gray_heron
Hi, Raessa-san
I will report the current situation.
I also considered Raeesa-san's procedure, but since it is difficult to SSH from the host to the container due to the limited environment,
Attempting to mount results in an error. What could be the cause of this error?
[Step]
# docker run --cap-add CAP_SYS_ADMIN --cap-add CAP_SYS_PTRACE --privileged ... -v/opt/intel/oneapi:/opt/intel/oneapi/...
# docker exec -it < container id >/bin/bash
root > cd
root > source/opt/intel/oneapi/setvars.sh
root > vtune -collect hotspots -knob sampling-mode=sw -target-pid <pid>
  (pid:The process ID of the container)
[Error]
vtune: Error: Failed to execute sep process.Data collection is interrupted.
vtune: Collection failed.
vtune: Internal Error
Regards.
RaeesaM_Intel
We were able to reproduce the issue on Ubuntu 18.04. There is no issue while running in Ubuntu 20.04. We are checking on resolving the issue on 18.04 , will get back to you with the updates.
Raeesa
RaeesaM_Intel
Thank you for your patience.
We do not currently support python profiling outside of docker. And we have some problems with attach mode when profiling Python. You can try installing Vtune in docker and profile the workload inside docker via launch mode
Also,please note that we only support python3.7, 3.8, IDP3.7 (Intel Distribution Python) in launch mode.
Raeesa
RaeesaM_Intel
We haven't heard back from you. Please let us know if you have any more queries.
Raeesa
RaeesaM_Intel
We haven't heard back from you. We are discontinuing monitoring this thread. Please raise a new query if you have further questions.
Raeesa
