Analyzers
5285 Discussions
vtss.sys caused Windows 11 bluescreen when installing DPC++ Compatibility Tool
Ayka
When the installation of Intel oneAPI Base Toolkit, v. 2022 proceeded to Intel DPC++ Compatibility Tool, my Windows 11 system froze and showed a blue screen with error code: DPC_WATCHDOG_VIOLATION. Before Intel DPC++ Compatibility Tool, the offline installer has already installed Intel Advisor, Intel oneAPI DPC++ Library, and Intel VTune(TM) Profiler. I tried to remove the installed components by Windows Install Clean Up and re-installed, however, there was still a blue screen. I viewed the Minidump file under C:\Windows\Minidump and analyzed the generated two dump files by Windbg Preview 1.2202.7001.0 (Administrator) using command `analyze -v`. The two dump files have the same results:
Microsoft (R) Windows Debugger Version 10.0.22549.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\022322-17062-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 22000 MP (6 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff807`4ba00000 PsLoadedModuleList = 0xfffff807`4c629bc0
Debug session time: Wed Feb 23 13:04:13.434 2022 (UTC + 8:00)
System Uptime: 0 days 10:39:20.422
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff807`4be16220 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:ffffbc00`b631a9f0=0000000000000133
2: kd> !analyze -v
*                        Bugcheck Analysis                                    *
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
	DISPATCH_LEVEL or above. The offending component can usually be
	identified with a stack trace.
Arg2: 0000000000001e00, The watchdog period.
Arg3: fffff8074c705330, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
	additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: TickPeriods                                   ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 3187
    Key  : Analysis.DebugAnalysisManager
    Value: Create
    Key  : Analysis.Elapsed.mSec
    Value: 9285
    Key  : Analysis.Init.CPU.mSec
    Value: 577
    Key  : Analysis.Init.Elapsed.mSec
    Value: 31147
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 99
FILE_IN_CAB:  022322-17062-01.dmp
DUMP_FILE_ATTRIBUTES: 0x1808
  Kernel Generated Triage Dump
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff8074c705330
BUGCHECK_P4: 0
DPC_TIMEOUT_TYPE:  DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
STACK_TEXT:
ffffbc00`b631a9e8 fffff807`4bcdb5ff     : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff807`4c705330 : nt!KeBugCheckEx
ffffbc00`b631a9f0 fffff807`4bcdb211     : 00001a15`8a6caa8b ffffbc00`b6300180 ffff58e6`318cc154 fffff807`4bd98775 : nt!KeAccumulateTicks+0x20f
ffffbc00`b631aa60 fffff807`4bcd8246     : 00000000`0025761b 00000000`00165426 00000059`50980180 00000000`00000000 : nt!KiUpdateRunTime+0x61
ffffbc00`b631aac0 fffff807`4bcd9552     : ffffab09`bd4ef750 00000000`00000000 fffff807`4c62b380 00000000`00000000 : nt!KiUpdateTime+0x686
ffffbc00`b631aeb0 fffff807`4bcd6e82     : ffffab09`bd4ef750 ffff8002`310aff50 ffff8002`00000000 00000000`00000002 : nt!KeClockInterruptNotify+0x272
ffffbc00`b631af40 fffff807`4bc8d720     : 00000059`50a80a9c ffff8002`310afea0 ffffbc00`b6a93970 00000000`00000000 : nt!HalpTimerClockInterrupt+0xe2
ffffbc00`b631af70 fffff807`4be17e2a     : ffffab09`bd4ef7d0 ffff8002`310afea0 00000000`00000000 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0xa0
ffffbc00`b631afb0 fffff807`4be183f7     : 00000000`bb37c832 00000000`00000001 00000000`00000000 fffff807`4bd59e4b : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
ffffab09`bd4ef750 fffff807`4bc95e1c     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
ffffab09`bd4ef8e0 fffff807`4bc95de1     : fffff807`4c64d118 ffffbc00`b6300180 ffff4fef`3af39304 ffff4fef`00000002 : nt!KxWaitForSpinLockAndAcquire+0x2c
ffffab09`bd4ef910 fffff807`4bf20b89     : 00000000`00000000 00000000`00000000 00000000`0108fda0 00000000`02d2fb34 : nt!KeAcquireSpinLockRaiseToDpc+0xc1
ffffab09`bd4ef940 fffff807`4c28d2b8     : 00000000`00000008 00000000`00000000 00000000`00000000 ffff8002`74aab1c0 : nt!HalpRegisterProfileSourceInterruptHandler+0x19
ffffab09`bd4ef970 fffff807`ac4b1dbc     : ffff8002`736d6d00 ffff8002`5b22c080 00000000`779936e0 00000000`02d2fa0c : nt!HalpSetSystemInformation+0xabae8
ffffab09`bd4ef9a0 ffff8002`736d6d00     : ffff8002`5b22c080 00000000`779936e0 00000000`02d2fa0c 00000000`00d5c000 : vtss+0x1dbc
ffffab09`bd4ef9a8 ffff8002`5b22c080     : 00000000`779936e0 00000000`02d2fa0c 00000000`00d5c000 00000000`00000000 : 0xffff8002`736d6d00
ffffab09`bd4ef9b0 00000000`779936e0     : 00000000`02d2fa0c 00000000`00d5c000 00000000`00000000 00000000`00000000 : 0xffff8002`5b22c080
ffffab09`bd4ef9b8 00000000`02d2fa0c     : 00000000`00d5c000 00000000`00000000 00000000`00000000 fffff807`4be28775 : 0x779936e0
ffffab09`bd4ef9c0 00000000`00d5c000     : 00000000`00000000 00000000`00000000 fffff807`4be28775 ffff8002`724e2080 : 0x2d2fa0c
ffffab09`bd4ef9c8 00000000`00000000     : 00000000`00000000 fffff807`4be28775 ffff8002`724e2080 ffff8002`54e99af0 : 0xd5c000
SYMBOL_NAME:  vtss+1dbc
MODULE_NAME: vtss
IMAGE_NAME:  vtss.sys
STACK_COMMAND:  .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET:  1dbc
FAILURE_BUCKET_ID:  0x133_ISR_vtss!unknown_function
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {9bea1b25-7b12-a130-9e47-df6b77a6b755}
Followup:     MachineOwner
It seems that the previously installed Intel VTune(TM) Profiler has some errors.
The system information is:
Processor: Intel(R) Core(TM) i7-8750H CPU @ 2.20 GHz  2.21 GHz
Windows version: Windows 11 21H2
Operating system version: 22000. 493
Experience pack version: 1000.22000.493.0
System type: 64-bit operating system based on x64 processor
Ayka
