Analyzers
5250 Обсуждение
vtune 2021 0x40000024(no data) error for hardware event based sampling
111alan
Новичок
21 531Просмотр.
Was testing some apps on an i7 11700K platform. Since the old parallel studio 2020 does not support this CPU any longer I installed the latest one-API. The problem is, the hardware event based sampling in all profiles stops working and throws a 0x40000024 no data error when finalizing. User mode sampling seems to have no issue.
The applications I'm trying to test work with older versions of vtune and cpu without a problem. And I've already updated the ME/chipset/serialio driver to the latest version listed on motherboard's vendor site(gigabyte Z590M gamingX). Any idea about what's the cause of this? Thanks.
0 баллов
29 Ответы
Kevin_O_Intel1
Сотрудник
5 292Просмотр.
Thanks.... getting some feedback from team
Kevin_O_Intel1
Сотрудник
5 278Просмотр.
Could you also send C:\Users\Kagamine\AppData\Local\Temp\amplxe-log-Kagamine\2021-06-01-20-58-32-549.vtune.exe\crash_info.txt
111alan
Новичок
5 272Просмотр.
Here.
Kevin_O_Intel1
Сотрудник
5 275Просмотр.
Kevin_O_Intel1
Сотрудник
5 270Просмотр.
Thanks... I think I have all I need to file a bug report. I'll let you know
Kevin_O_Intel1
Сотрудник
5 245Просмотр.
We have analyzed the issue... a fix has been implemented and will be in a future release 2021.5
111alan
Новичок
5 094Просмотр.
Here's the files and outputs generated on 11700K platform I got my hands on again, in case you also need them.
matthias-vigelius
Начинающий
5 000Просмотр.
it works now for me. Thanks heaps for your help!
111alan
Новичок
4 968Просмотр.
Mine works on 11700K now too. Thanks. I'll try on IcelakeSP when I have time.
Ответить
