Analyzers
5255 Discussions
vtune can not get the call stack
Wang_Ruifeng
HI, all.        I use vtune to help men get the applicatin call stack, but have some problem.
     if i do not add the static before the functions, the vtune can't get the call stack of the functions.for example:
if i do not add the static,the vtune will only get two funtion:testa,testb
if add the static,the vtune will get the call stack.  so my question is why the vtune can't get the call stack and the words 'static'  effect it?
my computer configuration:
 CPU:Intel E5504 2.0G
 OS: Suse 11 Sp1
GGCC: (SUSE Linux) 4.3.4 [gcc-4_3-branch revision 152973]  CC: (SUSE Linux) 4.3.4 [gcc-4_3-branch revision 152973
Wang_Ruifeng
 static int testa(int a)
 static int testb(int b)
    return testa(b)
David_A_Intel1
Hi Wang:
What compiler options are you using?  Most likely, optimization is inlining the functions and, thus, you won't see call stacks for these functions.
Wang_Ruifeng
OS: Suse 11 Sp1
if i use the gcc 4.2.4,i can not get the call stack.
but if i use the gcc 4.3.4,i can get the call stack with the same source file and makefile.  why??
