Analyzers
vtune on FC6
maziar_98
Hi all,
Has anybody got vtune working properly on FC6. I downloaded the vtune 8.0.4 and built the drivers and was able to bring it up and do some sampling but still vtune has some problems and callgraph gives errors and doesn't work on FC6.
Also I was wondering if there is a way to start multiple instances of your app simultaneously in vtune and get sampling of all of them in one place.
thanks
Andrey_G_Intel1
Thereare several known issues with CG collection on FC6. They will be adressed infuture versions of VTune.
You can create a script that runs several instances of your application. Then you will be able to collect sampling for all of themduring one sampling run. In sampling results you will see sampling data for every process.
Andrey
Matt_F_1
Do you know approximately when this issue will be corrected? I am currently trying to evaluate VTune on FC6 for purchase.
Matt
