Analyzers
5248 Discussions
vtune remote ssh connection fails
dvirtz
I'm trying to connect from MacOS Big Sur to a remote ubuntu machine.
I've setup passwordless ssh and installed the target package:
 % ssh dyitzchaki@dasher-2T4s /home/dyitzchaki/vtune_profiler_target/bin32/amplxe-runss -V
Intel(R) oneAPI VTune(TM) Profiler 2021.2.0 (build 615922) Data Collector
Copyright (C) 2009-2021 Intel Corporation. All rights reserved.
But VTune still complains about not being able to connect:
- Please, check that the command `'/home/dyitzchaki/vtune_profiler_target/bin32/amplxe-runss -V'` is run successfully on the target.
- VTune cannot detect remote machine configuration.
 In the console I run vtune-gui from I can see
[25034:1109/135724.141694:ERROR:ssl_client_socket_impl.cc(981)] handshake failed; returned -1, SSL error code 1, net_error -207
I was able to connect to this machine in the past from an older mac.
This is my configuration:
SSH destination
VTune Profiler installation directory on the remote system
Temporary directory on the remote system
/tmp
Version: 2021.8.0
OS: macOS 11.6.1
RahulU_Intel
Thanks for posting in Intel communities. We are trying to reproduce your issue from our side. We will update you soon.
Rahul
RahulU_Intel
Could you please share with us the configuration of the Ubuntu machine which you are trying to connect to.
Thanks and Regards
Rahul
dvirtz
Host dasher-test
  HostName <hidden>
  User ubuntu
  ProxyCommand ssh -W %h:%p  <hidden> -p <hidden>
  StrictHostKeyChecking no
Ubuntu version is 18.04.
What else do you need?
RahulU_Intel
We tried reproducing your issue from our side. We were successfully able to connect to remote ubuntu machine and run analysis on it. Could you please make sure that you have configured the linux target system correctly and try running remote performance analysis on the remote ubuntu machine by following the steps in the given link:
https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/command-line-interface/running-command-line-analysis/configuring-analysis-options-from-the-command-line/collect-data-remote-linux-systems-command-line.html
For configuring remote ubuntu machine you can follow the below link:
https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/set-up-analysis-target/linux-targets/remote-linux-target-setup/configuring-ssh-access-for-remote-collection.html#configuring-ssh-access-for-remote-collection_LIN
Thanks and Regards
Rahul
dvirtz
Thanks Rahul.
I went over the docs again and verified everything is setup correctly.
I did notice though that command-line profiling does work but the GUI still shows the same errors as above.
RahulU_Intel
We tried reproducing your issue at our end. We were able to do the profiling through GUI. Could you please share with us the screenshot of your configuration in GUI and also the error you are getting. Could you please confirm that in the "WHERE" pane of VTune Gui for the fields "VTune profiler installation directory on the remote system" and "Temporary directory on the remote system" you are giving a location of any temporary directory and not the path of application in the VTune directory on the remote system(We have also attached a screenshot for your reference). After doing the steps for "WHERE" pane you have to click on Deploy. Also could you please confirm that in the "WHAT" pane of the VTune Gui you have given the right path for the application you want to do the profiling on.
Hope this helps.
Thanks and Regards
Rahul
dvirtz
GUI screenshot (not working):
CLI screenshot (working):
RahulU_Intel
We are working on this internally. We will update you soon with an update.
Thanks and Regards
Rahul
RahulU_Intel
We are sorry for the delay. Could you please confirm you clicked on the "Deploy" button in the "WHERE" pane. Also Could you please share with us the log files generated in the /tmp/vtune_profiler_target.
Thanks and Regards
Rahul
dvirtz
Thanks for the reply.
The above screenshot is after clicking "Deploy". I don't see any logs in /tmp/vtune_profiler_target:
(dasher-3.6.9) dyitzchaki@r740-poptest:~/dasher$ ls -l /tmp/vtune_profiler_target/
total 56
drwxrwxr-x  2 dyitzchaki dyitzchaki  4096 Nov 28 10:38 bin32
drwxrwxr-x  6 dyitzchaki dyitzchaki  4096 Nov 28 10:38 bin64
drwxrwxr-x 11 dyitzchaki dyitzchaki  4096 Nov 28 10:38 config
drwxrwxr-x  4 dyitzchaki dyitzchaki  4096 Nov 28 10:38 lib32
drwxrwxr-x  6 dyitzchaki dyitzchaki 12288 Nov 28 10:38 lib64
drwxrwxr-x  3 dyitzchaki dyitzchaki  4096 Nov 28 10:38 message
drwxrwxr-x  3 dyitzchaki dyitzchaki  4096 Nov 28 10:38 resource
drwxrwxr-x  5 dyitzchaki dyitzchaki  4096 Nov 28 10:38 sepdk
-rwxr-xr-x  1 dyitzchaki dyitzchaki  1937 Sep 28 20:05 sep_vars_busybox.sh
-rwxr-xr-x  1 dyitzchaki dyitzchaki  2291 Sep 28 20:05 sep_vars.sh
drwxrwxr-x  3 dyitzchaki dyitzchaki  4096 Nov 28 10:38 socwatch
drwxrwxr-x  3 dyitzchaki dyitzchaki  4096 Nov 28 10:38 vpp
RahulU_Intel
Sorry for the delay. We looked into your case. Could you please check that your destination Ubuntu machine is up and running, and you are able to ping to it. Also could you please try giving the IP of your Ubuntu machine in the SSH Destination field of the WHERE pane. Like instead of dyitzchaki@dasher-2T4s you can try giving dyitzchaki@ip_of_ubuntu_machine.
Hope this helps.
Thanks & Regards
Rahul
dvirtz
Hi Rahul.
I'm connecting to the machine via a proxy so I can't connect with the IP directly.
Dvir
RahulU_Intel
Could you please confirm that your configuration is done correctly as you are connecting with the proxy. To set up your remote target for profiling you can follow the below link:
https://www.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top/configuration-recipes/profiling-remote-target-through-proxy.html
Rahul
dvirtz
Using nc on ProxyCommand doesn't work for me.
If I set
  ProxyCommand ncat --proxy-type socks4 --proxy-auth <proxy_user> --proxy <proxy> %h %p
I get
Ncat: Proxy connection failed.
from ssh.
With the following ProxyCommand
  ProxyCommand ssh -W %h:%p <proxy>
I can connect successfully without a password.
RahulU_Intel
We are checking on this internally. We will get back to you soon with an update.
Rahul
AthiraM_Intel
Sorry to inform you that we were unable to reproduce the issue from our side. We tried to replicate your issue in different environments and it's working fine for us. We tried with MacOS(11.6.3) and AWS remote target .We were able to profile successfully using both the command line and through VTune GUI.
Please work with your system administrator to check your system settings and proxy.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
