when i'm tring to colect data with vtune
amplxe: Error: [Instrumentation Engine]: Source/pin/injector_nonmac/auxvector.cpp: CopyAux: 291: unexpected AUX VEC type 26
os: arch linux
kernel vs: 4.11.3-1
vtune_amplifier_xe_2017
please specify the hardware you are working on.
Also please write an exact VTune version you used or just upload a broken result.
vendor_id       : GenuineIntel
	cpu family      : 6
	model           : 58
	model name      : Intel(R) Core(TM) i3-3120M CPU @ 2.50GHz
	stepping        : 9
	microcode       : 0x17
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rd
	tscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 c
	x16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave avx f16c lahf_lm epb tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms x
	saveopt dtherm arat pln pts
vtune_amplifier_xe_2017.3.0.510739
i guess pin is causing the problem, running it without the ' -ifeellucky ' flag i get the following
A: Source/pin/injector_nonmac/auxvector.cpp: CopyAux: 291: unexpected AUX VEC type 26 NO STACK TRACE AVAILABLE Detach Service Count: 1 Pin 3.2 Copyright (c) 2003-2016, Intel Corporation. All rights reserved. @CHARM-VERSION: $Rev: 81720 $ C: Injector exited with signal 6 E: Wait for injector failed: No child processes fish: './pin -appdebug -- ~/CLionProj…' terminated by signal SIGILL (Illegal instruction)
how can a force the ' -ifeellucky ' in amplxe-cl?
Support for kernels 4.10 and newer is not available in Pin version of VTune Amplifier XE 2017 U3. It will be included in future releases.
You can try the env variable below to propagate the flag:
AMPLXE_MORE_PIN_OPTIONS='-ifeellucky'
Regards, Katya
For reference, the corresponding environment variable for Advisor is: ADVIXE_MORE_PIN_OPTIONS.
	It's possible to use the GUI along with the option:
ADVIXE_MORE_PIN_OPTIONS='-ifeellucky' advixe-gui
Ekaterina L. (Intel) wrote:Hello,
Regards, Katya
How to fix this issue if I am running VTune Amplifier Host from macos, and the target is Linux?
Using this env variable worked when running vtune directly on linux.
Best,
Jovan
