This is Siddesh from Flex Component Engineering Team.
We are working on some of your manufacturing parts and require information on the below blank cells. Could you please provide below MPN details as quick as possible as it's an urgent request from our site.
End Customer: CAMBIUM
Flex Manufacturing Site: Gaud South (Mexico)
Looking forward for response.
ITEM NUMBER |
CNL1H-P008256 |
MPN_DESCRIPTION |
IC,FPGA,ARRIA 10,10AS048E3F29I2SG,0.92V TO 3.3V,FBGA-780 1.0MM,-40C TO 100C |
MANUFACTURER PART NUMBER |
10AS048E3F29I2SG |
DESCRIPTION MATCHES WITH MPN (YES/NO)? |
GIVEN MPN IS CORRECT & ORDERABLE/ INCORRECT/ INVALID ? |
IS THIS PART AVAILABLE T&R PACKAGING OPTION (YES/NO)? |
IF YES, PROVIDE CORRECT ORDERABLE TAPE AND REEL PART NUMBER ? |
LIFE CYCLE STATUS (ACTIVE OR OBSOLETE OR NRND) ? |
IF NRND, PLEASE PROVIDE LTB AND LTS DATE ? |
IF OBSOLETE, SUGGEST EXACT DROP-IN REPLACEMENT |
MOUNTING TYPE: SMT (YES/NO) ? |
PACKAGING (TAPE & REEL, ROLL,TRAY,TUBE AND BULK etc.) ? |
MOISTURE SENSITIVITY LEVEL (MSL) ? |
CASE SIZE/ PACKAGE (SMD,SOT,0603,FBGA SMA,0201 etc.) |
SHELF LIFE (IN DAYS) |
ROHS COMPLIANT (YES/NO) ? |
PART MARKING |
DATASHEET LINK// DATASHEET// DRAWING// SPECIFICATION SHEET |
Please find the below answer,
DESCRIPTION MATCHES WITH MPN (YES/NO)? - Refer PartDetail (intel.com)
GIVEN MPN IS CORRECT & ORDERABLE/ INCORRECT/ INVALID ? - Orderable through Intel Authorize Distributor
IS THIS PART AVAILABLE T&R PACKAGING OPTION (YES/NO)? - NO
IF YES, PROVIDE CORRECT ORDERABLE TAPE AND REEL PART NUMBER ? -N/A
LIFE CYCLE STATUS (ACTIVE OR OBSOLETE OR NRND) ? - ACTIVE
IF NRND, PLEASE PROVIDE LTB AND LTS DATE ? - N/A
IF OBSOLETE, SUGGEST EXACT DROP-IN REPLACEMENT - N/A
MOUNTING TYPE: SMT (YES/NO) ? - YES
PACKAGING (TAPE & REEL, ROLL,TRAY,TUBE AND BULK etc.) ? - TRAY
MOISTURE SENSITIVITY LEVEL (MSL) ? - Printed on moisture barrier bag
CASE SIZE/ PACKAGE (SMD,SOT,0603,FBGA SMA,0201 etc.) - FineLine Ball-Grid Array (FBGA)
SHELF LIFE (IN DAYS) - Indicated in the Moisture Barrier Bag (MBB) label
ROHS COMPLIANT (YES/NO) ? - YES
PART MARKING - You can refer What is the top side marking format for Altera devices? (intel.com)
DATASHEET LINK// DATASHEET// DRAWING// SPECIFICATION SHEET - You can refer Arria 10 Device Overview
Aqid Ayman
HI @AqidAyman_Intel ,
Thank you for your quick support.
Can you confirm on MSL and Shelf Life for MPN: 10AS048E3F29I2SG, As it is important for us to know what information this MPN have for MSL and shelf life (in days, months, years)
For your reference I also provided you a note.
Could you please give update asap as it's urgent request from our site.
END CUSTOMER: CAMBIUM
FLEX MANUFACTURING SITE: GAUD SOUTH(MEXICO)
Note:-
- MSL: The MSL is the MOISTURE SENSITIVY LEVEL of the material. There are some levels that manifest the amount of time and the humidity that the material can handle before baking it.
- Shelf life : Shelf life is the length of time that a commodity may be stored without becoming unfit for use, consumption, or sale. In other words, it might refer to whether a commodity should no longer be on a shelf
Looking forward your quick response.
Siddesh Chavan
Hello Siddesh Chavan,
Regarding your question on MPN: 10AS048E3F29I2SG, please find below answer:
Moisture Sensitivity Level (MSL):
Moisture Level= 3
Moisture/Reflow Sensitivity Classification: Moisture sensitive and must be dry packed in accordance with J-STD-033.
Floor Life: 168 hours
Conditions: < or = 30C/60% RH
You can refer FPGA MSL Calculator (intel.com) for your reference.
Shelf life:
Please be informed that Intel devices has shelf life of 36 months. You can refer to the adv0908.pdf and the latest revision adv1818.pdf.
Aqid Ayman
Correction on the link for checking the MSL, you can refer to FPGA MSL Calculator (intel.com) and enter the part number in the “Search Part Number” box to obtain the MSL rating.
Thank you
We do not receive any response from you to the previous question/reply/answer that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
