Dear Intel team,
Thank you for your support.
We have problem the Dev board DK-DEV-1SGX-L-A.
I believe our specialist Aaron-san open the case for us.
Case# 00777840
The customer purchased two of those.
When he applied power, LED is off and cooling fan isn't moving at all. But other one does and perfectly fine.
Could you verify this issue as defective?
Thank you for your patience.
Kind Regards,
Takashi
T4513600
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Nazrul Naim
This case will be closed and will be moved to IPS case 00781874.
Nazrul Naim
