Does anyone here have a datasheet for part#: 10AS022C3U19I2LPAA SRBW0?
Would like to request to obtain one. Urgent request.
If Intel request for an NDA, please send me to complete the form, thanks!!
- Tags:
- URGENT!
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
There's no package drawing or pin outs in this datasheet?
For the pin out and package drawing it is provided in a different document.
For the Package Drawing you can get it by accessing the link : https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/package.html?...
For the pin out you can get by accessing the link : https://cdrdv2.intel.com/v1/dl/getContent/666784?fileName=pcg-01017-683814-666784.pdf
Hope that answer your question,
Nazrul Naim
Hi Nazrul,
Thank you for the package drawing showing the pin outs. The other link i reviewed only
shows the pin names but no pin association? For Example: Lets says VCC. The datasheet only shows the
pin name as Vcc. Sinced it's a BGA, I'm looking for something like Vcc= A2. A2 "BGA Ball" is Vcc.
Sorry, What I'm trying to say is I need a datasheet that will show the pin name and BGA ball location.
The datasheet you provided only show the pin name. I hope this makes sense.
Can anyone tell me is this part#: 10AS022C3U1912LPAA SR8W0 is 10 GX? GT? or SX?
The datasheet that was provided only shows the "Pin Name" not the location?
Do we have another datasheet?
This pin out below is not from this device but I'm using it as an Example so you would understand.
