Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Error compiling OpenCL kernel for FPGA after license install
anaza3
I just bought a Quartus license and installed it. I am trying to use the Opencl compiler(I used to be able to use it with no problem on trial license). when I run the compiler I get this error:
/tools/intelFPGA/18.0/hld/board/trasic/de5net/tests/swap_mem_malware$ aoc device/swap_mem.cl -o bin/swap_mem.aocx --board de5net_a7 --report --
profile
Warning: Command has been deprecated. Please use -board=<value> instead of --board <value>
Warning: Command has been deprecated. Please use -report instead of --report
Warning: Command has been deprecated. Please use -profile instead of --profile
aoc: Warning: no argument provided for the option -profile, will enable profiling for all kernels by default
aoc: Selected target board de5net_a7
aoc: Running OpenCL parser....
/tools/intelFPGA/18.0/hld/board/trasic/de5net/tests/swap_mem_malware/device/swap_mem.cl:14:34: warning: declaring kernel argument with no 'restrict' may lead to low kernel performance
                 __global float *A,
/tools/intelFPGA/18.0/hld/board/trasic/de5net/tests/swap_mem_malware/device/swap_mem.cl:15:18: warning: declaring kernel argument with no 'restrict' may lead to low kernel performance
                 __global int* trigger,
2 warnings generated.
aoc: Optimizing and doing static analysis of code...
! The report below may be inaccurate. A more comprehensive
! resource usage report can be found at swap_mem/reports/report.html
; Estimated Resource Usage Summary                                   ;
; Resource                               + Usage                     ;
; Logic utilization                      ;   20%                     ;
; ALUTs                                  ;   13%                     ;
; Dedicated logic registers              ;    9%                     ;
; Memory blocks                          ;   23%                     ;
; DSP blocks                             ;    1%                     ;
Compiling for FPGA. This process may take a long time, please be patient.
Error (138079): Current license file does not support partial reconfiguration. The Quartus Prime software automatically disabled partial reconfiguration support on all partitions.
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 0 warnings
Error: Flow compile (for project /tools/intelFPGA/18.0/hld/board/trasic/de5net/tests/swap_mem_malware/bin/swap_mem/top) was not successful
Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
Error (23031): Evaluation of Tcl script /tools/intelFPGA/18.0/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 10 errors, 0 warnings
Error: Compiler Error, not able to generate hardware
Any idea what the problem is?
this the content of quartus_sh_compile.sh:
Info: *******************************************************************
Info: Running Quartus Prime Shell
    Info: Version 18.0.0 Build 614 04/24/2018 SJ Standard Edition
    Info: Copyright (C) 2018  Intel Corporation. All rights reserved.
    Info: Your use of Intel Corporation's design tools, logic functions
    Info: and other software and tools, and its AMPP partner logic
    Info: functions, and any output files from any of the foregoing
    Info: (including device programming or simulation files), and any
    Info: associated documentation or information are expressly subject
    Info: to the terms and conditions of the Intel Program License
    Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
    Info: the Intel FPGA IP License Agreement, or other applicable license
    Info: agreement, including, without limitation, that your use is for
    Info: the sole purpose of programming logic devices manufactured by
    Info: Intel and sold by Intel or its authorized distributors.  Please
    Info: refer to the applicable agreement for further details.
    Info: Processing started: Wed Jul 29 22:48:07 2020
Info: Command: quartus_sh --flow compile top -c top
Info: Quartus(args): compile top -c top
Info: Using INI file /tools/intelFPGA/18.0/hld/board/trasic/de5net/tests/swap_mem_malware/bin/swap_mem/quartus.ini
Info: Project Name = /tools/intelFPGA/18.0/hld/board/trasic/de5net/tests/swap_mem_malware/bin/swap_mem/top
Info: Revision Name = top
    Info: Processing started: Wed Jul 29 22:48:34 2020
Info: Command: quartus_sh -t scripts/pre_flow.tcl compile top top
Info: Quartus(args): compile top top
Info: Deleting incremental_db to ensure imported partition is only used
Info: Checking for OpenCL SDK installation, environment should have INTELFPGAOCLSDKROOT defined
Info: INTELFPGAOCLSDKROOT=/tools/intelFPGA/18.0/hld
Info: Compiling CvP!
Info (23030): Evaluation of Tcl script scripts/pre_flow.tcl was successful
Info: Quartus Prime Shell was successful. 0 errors, 0 warnings
    Info: Peak virtual memory: 750 megabytes
    Info: Processing ended: Wed Jul 29 22:48:35 2020
    Info: Elapsed time: 00:00:01
    Info: Total CPU time (on all processors): 00:00:01
Info: Running Quartus Prime Analysis & Synthesis
    Info: Processing started: Wed Jul 29 22:48:38 2020
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off top -c top
    Error: Peak virtual memory: 909 megabytes
    Error: Processing ended: Wed Jul 29 22:49:08 2020
    Error: Elapsed time: 00:00:30
    Error: Total CPU time (on all processors): 00:00:30
    Error: Peak virtual memory: 804 megabytes
    Error: Processing ended: Wed Jul 29 22:49:09 2020
    Error: Elapsed time: 00:01:02
    Error: Total CPU time (on all processors): 00:01:01
this is how my license setup looks like:
HRZ
Valued Contributor III
Your Quartus license should support "Partial Reconfiguration" for you to be able to use it with OpenCL. Contact the person/entity you purchased the license from to add "Partial Reconfiguration" support.
AnilErinch_A_Intel
Hi Alireza,
Please let us know whether the previous discussion helped in resolving the issue and any further support is required.
Thanks and Regards
Anil
