Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Error enumerating AFCs: no driver available
wangyong
Dear admin,
When I connect to DevCloud for FPGA and login in as interactive mode, I want to run the oneAPI for FPGA sample code https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2BFPGA/ReferenceDesigns/gzip , when I try to run
aocl initialize acl0
it went wrong like this:
Error enumerating AFCs: not found
I also try to run my fpga binary, it also outputs like :
/var/spool/torque/mom_priv/jobs/876706.v-qsvr-1.aidevcloud.SC: line 2: 29031 Segmentation fault ./huff_compress.fpga ../data/src_file ../data/CTable
/usr/sbin/kill-illegit-procs: line 6: /etc/kill-illegit-procs.cfg: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: /dev/shm/kip-procs-1622108632.tmp: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: /dev/shm/kip-procs-1622108692.tmp: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: /dev/shm/kip-procs-1622108752.tmp: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: /dev/shm/kip-procs-1622108812.tmp: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: 19214 Killed ps --no-headers -eo uid,pid,ppid
19215 | sort -n
19216 | awk '{if ((2000<$1) && ($1<61184)) {print $0}}' >> $T
so please help confirm is this devcloud's problem ?
Wang Yong
Hazlina_R_Intel
Sorry that we overlooked to respond to you on this. Is this issue still persists?
Saikiranbelana
yes, I'm getting the same errors on docker with Intel RTE. Can you please help us out?
Saikiran
