Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Errors on Intel Acceleration Stack Version 1.2 with Intel Arria 10 GX FPGA
JDALO
when I execute "fpgabist nlb_mode_3.gbs", error "PCIe error detected" is reported,see picture1 and 2.
1.png2.pngwhen I excute "fpgabist dma_afu.gbs", another error "Failed Test:fpga_dma_test" is reported,see picture 3.
And my development environment is Intel Acceleration Stack Version 1.2 with Intel Arria 10 GX FPGA.
SengKok_L_Intel
May I know what OS you are using? Could you please provide the output of sudo lspci –s $bdf -vvv (e.g sudo lspci -s 81:00.0 -vvv)?
Regards -SK
JDALO
Hi,My OS is CentOS7.2 and the output of sudo lspci -s 81:00.0 -vvv is as below:
SengKok_L_Intel
Could you please read the device control register by using command below?
sudo setpci -d 8086:094C 0x78.L
This is to check if bit 7:5 is set to 001b for 256 bytes max payload size? If not, please configure the bit 7:5 as 001b, and then run the test again.
For example:
sudo setpci -d 8086:094C 0x78.L=0009203e (please change bit 7:5 as 001, the rest remain the same as what you read out)
If above do not help, please also read the uncorrectable & correctable status register to further understanding the problem.
sudo setpci -d 8086:094C 0x110.L
sudo setpci -d 8086:094C 0x104.L
Regards -SK
SengKok_L_Intel
​Just to clarify, for Arria 10 device, the Device control register is at 0x88 (0x78 is for Stratix 10 device). Therefore, the command should be sudo setpci -d 8086:094C 0x88.L
JDALO
f1becd33b87b8eecf6d5b26c278ba42.png​I have run the commandsudo setpci -d 8086:094C 0x88.L,the value is 0009283f while 7:5bit is 001b. And what can I do next to solve the errors.
SengKok_L_Intel
​Could you please share the output of correctable/uncorrectable status "before" and "after" run the fpgabist nlb_mode_3.gbs test? How many boards encounter this error? Do you try to program the flash again, and re-install the DCP 1_2 stack?
Below is the command:
Regards -SK
