Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Generating AFU for Arria 10 GX PAC
AIvan11
I am trying to run minimal flow for the hello sample:
$ cd $OPAE_PLATFORM_ROOT/hw/samples/hello_afu $ afu_synth_setup --source hw/rtl/filelist.txt build_synth $ cd build_synth $ $OPAE_PLATFORM_ROOT/bin/run.sh
https://www.intel.com/content/www/us/en/programmable/documentation/bfr1522087299048.html#unm1523051477085
to generate an AFU.
Synthesis fails with the following error. I googled it, but nothing comes up.
Error (19877): Partial reconfiguration no longer supports synthesis revisions Error: Flow failed: Error: Quartus Prime Synthesis was unsuccessful. 2 errors, 9 warnings Error: Peak virtual memory: 1279 megabytes Error: Processing ended: Wed Oct 10 14:45:57 2018 Error: Elapsed time: 00:00:08 Error (23035): Tcl error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.   while executing "execute_module -dont_export_assignments -tool syn" (procedure "synthesize_persona_impl" line 14) invoked from within "synthesize_persona_impl $synth_rev" (procedure "compile_pr_revision" line 18) invoked from within "compile_pr_revision $options(impl)" (procedure "main" line 110) invoked from within "main" invoked from within "if {($::quartus(nameofexecutable) == "quartus") || ($::quartus(nameofexecutable) == "quartus_pro") || ($::quartus(nameofexecutable) == "qpro")} {   #..." (file "./a10_partial_reconfig/flow.tcl" line 1039)
Do you know what may be causing it? Thanks in advance.
AIvan11
Yes, thank you. Downgrading to 17.1 and installing the patches provided with the acceleration stack solved the error.
JohnT_Intel
From my understanding, you are using Quartus 18.0 or later version which is causing the issue. I would recommend you to use Quartus 17.1 Pro edition in order to compile your design.​
AIvan11
