Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
I am having the same issue in OpenVINO 2019R1. classification_sample but classification_sample -d HETERO:FPGA,CPU does not.
jjunn
And I install dev not rte,the right one. so I don't have /opt/altera/aocl-pro-rte/aclrte-linux64
link:https://software.intel.com/en-us/forums/computer-vision/topic/808441#comment-1940333
[****** openvino_test]$ classification_sample -m squeezenet1.1.xml -i $IE_INSTALL/demo/car.png -d HETERO:FPGA,CPU [ INFO ] InferenceEngine: API version ............ 1.6 Build .................. custom_releases/2019/R1.1_28dfbfdd28954c4dfd2f94403dd8dfc1f411038b [ INFO ] Parsing input parameters [ INFO ] Files were added: 1 [ INFO ] /opt/intel/openvino/deployment_tools/demo/car.png [ INFO ] Loading plugin   API version ............ 1.6 Build .................. heteroPlugin Description ....... heteroPlugin [ INFO ] Loading network files: squeezenet1.1.xml squeezenet1.1.bin [ INFO ] Preparing input blobs [ WARNING ] Image is resized from (787, 259) to (227, 227) [ INFO ] Batch size is 1 [ INFO ] Preparing output blobs [ INFO ] Loading model to the plugin FAILED to read auto-discovery string at byte 44. Full auto-discovery string value is 17 c12babe577632f8d6172495d8daa78017e42fb2a pac_a10 0 0 2 1024 0 4294967296 4294967296 8589934592 0 7 DLA_VERSION_4_4x2x16x64_fp11_sb18823_i1_actk8_poolk8_owk8_image224x224 0 128 0 0 1 0 1 0 0 0 0 1 1 1 3 1 1 1 0 bias_reader 256 128 0 0 1 0 1 0 2 2 1 8 2 1 8 0 0 1 1 1 3 1 1 1 0 config_reader 512 128 0 0 1 0 1 0 2 2 1 8 0 0 4 0 0 1 1 1 3 1 1 1 0 filter_reader 768 256 0 0 1 0 1 0 6 2 1 8 2 1 8 0 0 4 0 0 4 0 0 4 0 0 4 0 0 1 1 1 3 1 1 1 0 input_reader 1024 128 0 0 1 0 1 0 4 2 1 8 2 1 8 0 0 4 0 0 4 0 0 1 1 1 3 1 1 1 0 output_writer 1280 128 0 0 1 0 1 0 2 2 1 8 2 1 8 0 0 1 1 1 3 1 1 1 0 perf_writer 1536 128 0 0 1 0 1 0 1 2 1 8 0 0 1 1 1 3 1 1 1 0 acl_hal_mmd.c:1393:assert failure: Failed to initialize kernel interfaceclassification_sample: acl_hal_mmd.c:1393: l_try_device: Assertion `0' failed. Aborted (core dumped)
JohnT_Intel
May I know which aocx file do program into the board? could you try to program other aocx file to see if the classification_sample is working?
Have you try to follow the step use to install the board in https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux_fpga.html? Are you running in root?
jjunn
The aocx file that I used is 2019R1_RC_FP11_ResNet_SqueezeNet_VGG.aocx . I followed the step ,and I am running in root. The problem is the guide providing a runtime version. And I install the dev version in the right of the picture.
guide:https://docs.openvinotoolkit.org/latest/_docs_install_guides_PAC_Configure_2019R1.html
JohnT_Intel
Could you try other aocx file to see if you are facing the same issue?
jjunn
I am facing the same issue when I try other aocx file
JohnT_Intel
Could you try to performed diagnose on the board (aocl diagnose acl0)?
jjunn
FAILED to read auto-discovery string at byte 44. Full auto-discovery string value is 17 143eef84a4bc814da7279519731272a09efb9e52 pac_a10 0 0 2 1024 0 4294967296 4294967296 8589934592 0 6 DLA_VERSION_4_3x3x16x64_fp11_sb4096_i1_actk8_poolk8_normk8_owk8 0 128 0 0 1 0 1 0 0 0 0 1 1 1 3 1 1 1 0 bias_reader 256 128 0 0 1 0 1 0 1 2 1 8 0 0 1 1 1 3 1 1 1 0 config_reader 512 128 0 0 1 0 1 0 2 2 1 8 0 0 4 0 0 1 1 1 3 1 1 1 0 filter_reader 768 256 0 0 1 0 1 0 6 2 1 8 2 1 8 0 0 4 0 0 4 0 0 4 0 0 4 0 0 1 1 1 3 1 1 1 0 input_reader 1024 128 0 0 1 0 1 0 4 2 1 8 2 1 8 0 0 4 0 0 4 0 0 1 1 1 3 1 1 1 0 output_writer 1280 128 0 0 1 0 1 0 2 2 1 8 2 1 8 0 0 1 1 1 3 1 1 1 0 acl_hal_mmd.c:1393:assert failure: Failed to initialize kernel interfacediagnose: acl_hal_mmd.c:1393: l_try_device: Assertion `0' failed.
this is the error
jjunn
source /home/jiangjn/tools/inteldevstack/init_env.sh export CL_CONTEXT_COMPILER_MODE_ALTERA=3 export CL_CONTEXT_COMPILER_MODE_INTELFPGA=3 export INTELFPGAOCLSDKROOT="/home/jiangjn/tools/inteldevstack/intelFPGA_pro/hld" export ALTERAOCLSDKROOT="\$INTELFPGAOCLSDKROOT" export AOCL_BOARD_PACKAGE_ROOT="/home/jiangjn/tools/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/opencl_bsp" /home/jiangjn/tools/inteldevstack/a10_gx_pac_ias_1_2_pv/opencl/opencl_bsp/linux64/libexec/setup_permissions.sh source /home/jiangjn/tools/inteldevstack/intelFPGA_pro/hld/init_opencl.sh export IE_INSTALL="/opt/intel/openvino/deployment_tools" source /opt/intel/openvino/bin/setupvars.sh export PATH=$PATH:/home/jiangjn/inference_engine_samples_build/intel64/Release alias mo="python3.6 \$IE_INSTALL/model_optimizer/mo.py"
this is my init_openvino.sh
jjunn
what should I do to solve this problem?
jjunn
I can run the hellworld sample,but there is still a problem when runing 2019R1_RC_FP11_ResNet_SqueezeNet_VGG.aocx
JohnT_Intel
Have you try to run the diagnostic tools? Do you have another board to test it as I am suspect that the board might be damaged.
jjunn
jjunn
And it is a runtime version ,and I use a dev version ,and it should be sloved
JohnT_Intel
Could you check if you have "/opt/altera/aocl-pro-rte/aclrte-linux64" folder? The reason is that this is part of the OpenVINO installation. If you are able to find it then could you try to setup the environement for "INTELFPGAOCLSDKROOT " to this directory.
jjunn
Yes,I find it ,and the FPGA is running successfully.
But, I think it is the runtime problem. It did not solve the problem fundamentally.
because it notice me :
aoc was not found, but aocl was found. Assuming only RTE is installed.
And I have installed the DEV,not RTE .
JohnT_Intel
RTE version is sufficient when you are just running the demo. Could you change the environment for "INTELFPGAOCLSDKROOT " to "/opt/altera/aocl-pro-rte/aclrte-linux64", This should be able to help you based on the other forum discussion.
