Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
OFS : Data Path of QSFP from HE_HSSI
attdoner
Hi Team,
I am using N6001 with Intel OFS (OFS PCIe Attach) . I wanted to test data transfer from Host1 to Host2 as below.
Host1 -> N6001(Port0) -> OtherNIC(Port0) -> Host2.
Is there any sample application available in OPAE/OFS which performs this transaction? Can you please suggest.
In addition to above query, I wants to know how HE-HSSI sends data to QSFP?. The hssi application shows "No eth interface, so not honoring --eth-loopback". ( https://ofs.github.io/ofs-2024.1-1/hw/n6001/user_guides/ug_qs_ofs_n6001/ug_qs_ofs_n6001/  Section 7. Send traffic through the 10G AFU). Does this mean the HE_HSSI will not communicate with E-Tile or QSFPs (FIM) ?
Do I need to enable any parameters to pass over QSFPs?
Thankyou.
attdoner
Hi @JohnT_Intel ,
Can you provide the programming log of 100g. I want to cross verify the method of programming, to check whether I missed out any steps. I was not able to get the above log prints in 100g. Instead it used to get mbox_write
JohnT_Intel
I do not have issue on clearing the HSSI STAT from my side.
Below is my logging.
pggae@pggae-PowerEdge-R740:~$ sudo hssistats
Namespace(pcie_address=None, clear=False)
sbdf: 0000:d8:00.0
FPGA dev: {'segment': 0, 'bus': 216, 'dev': 0, 'func': 0, 'path': '/sys/class/fpga_region/region0', 'pcie_address': '0000:d8:00.0'}
args.hssi_grps[('dfl_dev.3', ['/sys/bus/pci/devices/0000:d8:00.0/fpga_region/region0/dfl-fme.0/dfl_dev.3/uio/uio0'], '0000:d8:00.0', 21)]
fpga uio dev:dfl_dev.3
--------HSSI INFO START-------
DFH           :0x3000000010002015
HSSI ID         :0x15
DFHv          :0.5
guidl          :0x99a078ad18418b9d
guidh          :0x4118a7cbd9db4a9b
HSSI version      :1.0
Firmware Version    :1
HSSI num ports     :2
Port0          :100GCAUI-4
Port4          :100GCAUI-4
--------HSSI INFO END-------
HSSI num ports: 2
HSSI Ports            |       port:0|       port:4|
tx_packets            |        102|         0|
rx_packets            |         0|        102|
rx_crc_errors          |         0|         0|
rx_align_errors         |         0|         0|
tx_payload_bytes         |        7646|         0|
rx_payload_bytes         |         0|        7646|
tx_pause             |         0|         0|
rx_pause             |         0|         0|
rx_errors            |         0|         0|
tx_errors            |         0|         0|
rx_unicast            |         0|        102|
rx_multicast           |         0|         0|
rx_broadcast           |         0|         0|
tx_discards           |         0|         0|
tx_unicast            |        102|         0|
tx_multicast           |         0|         0|
tx_broadcast           |         0|         0|
ether_drops           |         0|         0|
rx_total_bytes          |         0|        7826|
rx_total_packets         |         0|        102|
rx_undersize           |         0|         0|
rx_oversize           |         0|         92|
rx_64_bytes           |         0|         1|
rx_65_127_bytes         |         0|         1|
rx_128_255_bytes         |         0|         1|
rx_256_511_bytes         |         0|         0|
rx_512_1023_bytes        |         0|         3|
rx_1024_1518_bytes        |         0|         4|
rx_gte_1519_bytes        |         0|         0|
rx_jabbers            |         0|         0|
rx_runts             |         0|         0|
pggae@pggae-PowerEdge-R740:~$ sudo hssistats clear
usage: hssistats [-h] [--pcie-address PCIE_ADDRESS] [--clear]
hssistats: error: unrecognized arguments: clear
pggae@pggae-PowerEdge-R740:~$ sudo hssistats --clear
Namespace(pcie_address=None, clear=True)
sbdf: 0000:d8:00.0
HSSI ID         :0x15
DFHv          :0.5
HSSI version      :1.0
Firmware Version    :1
HSSI num ports     :2
Port0          :100GCAUI-4
Port4          :100GCAUI-4
HSSI num ports: 2
HSSI stats clearing ...
HSSI stats cleared
sbdf: 0000:d8:00.0
HSSI ID         :0x15
DFHv          :0.5
HSSI version      :1.0
Firmware Version    :1
HSSI num ports     :2
Port0          :100GCAUI-4
Port4          :100GCAUI-4
HSSI num ports: 2
tx_packets            |         0|         0|
rx_packets            |         0|         0|
tx_payload_bytes         |         0|         0|
rx_payload_bytes         |         0|         0|
tx_pause             |         0|         0|
rx_pause             |         0|         0|
rx_errors            |         0|         0|
tx_errors            |         0|         0|
rx_unicast            |         0|         0|
tx_discards           |         0|         0|
tx_unicast            |         0|         0|
ether_drops           |         0|         0|
rx_total_bytes          |         0|         0|
rx_total_packets         |         0|         0|
rx_oversize           |         0|         0|
rx_64_bytes           |         0|         0|
rx_65_127_bytes         |         0|         0|
rx_128_255_bytes         |         0|         0|
rx_512_1023_bytes        |         0|         0|
rx_1024_1518_bytes        |         0|         0|
rx_jabbers            |         0|         0|
rx_runts             |         0|         0|
JohnT_Intel
May I know if you have any other queries?
