Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
OFS : Data Path of QSFP from HE_HSSI
attdoner
Hi Team,
I am using N6001 with Intel OFS (OFS PCIe Attach) . I wanted to test data transfer from Host1 to Host2 as below.
Host1 -> N6001(Port0) -> OtherNIC(Port0) -> Host2.
Is there any sample application available in OPAE/OFS which performs this transaction? Can you please suggest.
In addition to above query, I wants to know how HE-HSSI sends data to QSFP?. The hssi application shows "No eth interface, so not honoring --eth-loopback". ( https://ofs.github.io/ofs-2024.1-1/hw/n6001/user_guides/ug_qs_ofs_n6001/ug_qs_ofs_n6001/  Section 7. Send traffic through the 10G AFU). Does this mean the HE_HSSI will not communicate with E-Tile or QSFPs (FIM) ?
Do I need to enable any parameters to pass over QSFPs?
Thankyou.
attdoner
Hi @JohnT_Intel ,
In addition to above queries, the Transfer rate shows throughput nearly 25Gbps for 10G using 'sudo hssi hssi_10g  --num-packets 1 '. But when I execute for 100G, I could see error message. Can I know what causes this issue? How to resolve this error?
$ sudo hssi hssi_100g --num-packets 10
[hssi_100g] [error] no accelerator found with id: 43425XX6-9XX2-3XX2-bXXa-aXXX4b53XXX2
JohnT_Intel
Are you running " sudo hssistats --clear" to clear the stat? I am able to clear the stat from my side without any issue.
May I know which image are you using for your board? I suspect that you are using 10G FIM which is why it is not able to detect the AFU GUID for it to run the test. The provided image is 2x4x25GbE.
You will need to change the FIM design to 100G design
attdoner
Hi @JohnT_Intel ,
I have tried " sudo hssistats --clear" still the values used to be there.
We are using https://github.com/otcshare/intel-ofs-fim/releases/tag/ofs-4.1.1.
Yes, Ethernet configurations: 2x4x25GbE.
* Whether the FIM in this link is 10G ?
* Do you use other image for 2x4x25GbE?
* Can we know is there any FIM with 100G ?
JohnT_Intel
Currently the official release image is 2x4x25GbE.
I am checking with engineering to see if we have this image.
attdoner
Hi @JohnT_Intel ,
    Thanks for the update.
    I tried with this FIM (https://github.com/otcshare/intel-ofs-fim/releases/download/ofs-3.2.1/FIM_x8_2x1x100G.zip ). Even the error is same.
[user@user ~]$ sudo fpgainfo phy
Intel Acceleration Development Platform N6001
Board Management Controller NIOS FW version: 3.15.1
Board Management Controller Build version: 3.15.1
//****** PHY ******//
Interface                        : DFL
Object Id                        : 0xF000000
PCIe s:b:d.f                     : 0000:01:00.0
Vendor Id                        : 0x8086
Device Id                        : 0xBCCE
SubVendor Id                     : 0x8086
SubDevice Id                     : 0x1770
Socket Id                        : 0x00
Ports Num                        : 01
Bitstream Id                     : 0x501060255341BA8
Bitstream Version                : 5.0.1
Pr Interface Id                  : 98c2df0a-7c39-5bda-9d5b-6a38550cd3d8
QSFP0                            : Not Connected
QSFP1                            : Not Connected
//****** HSSI information ******//
HSSI version                     : 1.0
Number of ports                  : 4
Port0                            :100GCAUI-4   UP
Port4                            :100GCAUI-4   UP
Port8                            :100GCAUI-4   DOWN
Port12                           :100GCAUI-4   DOWN
[user@user ~]$ sudo hssi hssi_100g
[2024-11-25 11:06:06.438] [hssi_100g] [error] no accelerator found with id: 43425ee6-92b2-4742-b03a-bd8d4a533812
JohnT_Intel
The reason is that particular FIM is having different Accelerator GUID. I am currently checking to see if we have example design for this testing.
attdoner
Hi @JohnT_Intel ,
Is there any update on example design ?
In addition to my query I have modified few changes in N6001 AFU, but I am facing mbox_write timeout as below
sudo hssi hssi_100g
100G loopback test
  port: 0
  eth_loopback: on
  num_packets: 1
  gap: none
  src_address: 11:22:33:44:55:66
    (bits): 0x112233445566
  dest_address: 77:88:99:aa:bb:cc
    (bits): 0x778899aabbcc
  pattern: random
  start size: 40
  end size: 2580
  end select: pkt_num
  eth:
  continuous mode: off
  monitor duration: 0 sec
No eth interface, so not honoring --eth-loopback. Try using the hssiloopback command instead.
mbox_write timed out [a]
JohnT_Intel
Unfortunately we do not have the design for the 100G. You will need to build the FIM with this command "./ofs-common/scripts/common/syn/build_top.sh --ofss tools/ofss_config/hssi/hssi_2x100.ofss n6001 work_n6001"
attdoner
Hi @JohnT_Intel ,
Thanks for the update, I will compile and get back to you.
Meanwhile, with 10g_hssi tests, I could see throughput difference.
TX Packet Count (N6001)TX Throughput(N6001) GB/s
125.7812
5016.0559
50015.5692
500015.5638
5000015.5708
50000015.5693
500000015.5692
958698015.5652
95869816.96E-07
100000000.643037
10000000000.177615
As packet count increases, the throughput decreases. In above table,
For Packet Count 1: The TX throughput = 25Gbps
For Packet Count 50: The TX throughput = 16.05Gbps
Can I know why the "throughput" values are lesser for higher packet counts?
JohnT_Intel
It will be limited due to traffic generator. When you have too much packet to sent, it is impacting the traffic generator to generate the packet needed.
attdoner
Hi @JohnT_Intel ,
With your previous reply "
I had tried this command , and I face the below issue.
sudo hssi hssi_100g
100G loopback test
  port: 0
  eth_loopback: on
  num_packets: 1
  gap: none
  pattern: random
  start size: 40
  end size: 2580
  end select: pkt_num
  eth:
JohnT_Intel
Can you share with me your bitstream?
attdoner
Hi @JohnT_Intel ,
I had attahced the bitstream generated using this command "./ofs-common/scripts/common/syn/build_top.sh --ofss tools/ofss_config/hssi/hssi_2x100.ofss n6001 work_n6001"
https://drive.google.com/file/d/1Vz35lGX3VPandzAgsU8NGwGR-9Z6ItOw/view?usp=sharing
Please let us know any update on this
JohnT_Intel
I observed that you are sharing .pof file. Can you share .bin file that I can directly load into the board?
omprasad
Subscribing for the same
JohnT_Intel
I have try the bin file that you provided and I do not observed the mbox error that you mention.
attdoner
Hi @JohnT_Intel ,
Can you please share the output of 100g using below command
sudo hssi hssi_100g
JohnT_Intel
Below is what I observed.
attdoner
Hi @JohnT_Intel ,
Can you please reshare the image.
The image is not able to view.
JohnT_Intel
