Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Which part of design example eth_e2e_e10 based on platform designer
User1582192733150209
Hello Sir?Madam
I am running the eth_e2e_e10 design example now.
I have a IP upgrading issue now .
When I open the Quartus pro GUI in linux, and open the dcd.qpf project , system reminder to upgrade several IP core, I can click button Launch IP upgrade Tools, and seems several IP cores be upgrade successfully except address_decide and sc_fifo, seems that processing must be done through platform designer, which fails to show up correctly.
May I know which part of design based on platform designer?
Because I can not lautch platform designer gui correctly, any steps I can take to solve this issue?
I guess the issue might be caught by JAVA, so I print java version here for reference.
thanks
Jim
[root@fig01 a10_gx_pac_ias_1_2_pv]# uname -a
Linux fig01 3.10.0-957.10.1.el7.x86_64 #1 SMP Mon Mar 18 15:06:45 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
[root@fig01 a10_gx_pac_ias_1_2_pv]# java -version
openjdk version "1.8.0_201"
OpenJDK Runtime Environment (build 1.8.0_201-b09)
OpenJDK 64-Bit Server VM (build 25.201-b09, mixed mode)
Some update , when I click the button Auto upgrade,Quartus printed below error information,any other way I can use to upgrade these IP if I can not open the qsys platform designer? thanks
Error: 2020.03.16.11:11:48 Error: Generation for Standard System (.qsys) files is not available in Pro, you can upgrade these files to Pro by opening them in Platform Designer for Quartus Pro.
Error: Quartus Prime Shell was unsuccessful. 15 errors, 0 warnings
Error: Peak virtual memory: 822 megabytes
Error: Processing ended: Mon Mar 16 11:12:26 2020
Error: Elapsed time: 00:00:50
Error: Total CPU time (on all processors): 00:02:00
Error(14923): Error upgrading Platform Designer file "../../hw/rtl/e10/fifo_scfifo/sc_fifo.qsys"
Error: 2020.03.16.11:12:14 Error: address_decode.rx_xcvr_half_clk.clk_in: rx_xcvr_half_clk.clk_in must be connected to a clock output
Error: 2020.03.16.11:12:14 Error: address_decode.rx_xcvr_half_clk.clk_in_reset: rx_xcvr_half_clk.clk_in_reset must be connected to a reset source
Error: 2020.03.16.11:12:14 Error: qsys-generate failed with exit code 3: 2 Errors, 0 Warnings
Error: 2020.03.16.11:12:16 Error: address_decode.rx_xcvr_half_clk.clk_in: rx_xcvr_half_clk.clk_in must be connected to a clock output
Error: 2020.03.16.11:12:16 Error: address_decode.rx_xcvr_half_clk.clk_in_reset: rx_xcvr_half_clk.clk_in_reset must be connected to a reset source
Error: 2020.03.16.11:12:16 Error: qsys-generate failed with exit code 3: 2 Errors, 0 Warnings
Error: 2020.03.16.11:12:17 Error: address_decode.rx_xcvr_half_clk.clk_in: rx_xcvr_half_clk.clk_in must be connected to a clock output
Error: 2020.03.16.11:12:17 Error: address_decode.rx_xcvr_half_clk.clk_in_reset: rx_xcvr_half_clk.clk_in_reset must be connected to a reset source
Error: 2020.03.16.11:12:17 Error: qsys-generate failed with exit code 3: 2 Errors, 0 Warnings
Error(14923): Error upgrading Platform Designer file "../../hw/rtl/e10/address_decoder/address_decode.qsys"
Error(11133): IP component QsysPrimePro with file "../../hw/rtl/e10/fifo_scfifo/sc_fifo.qsys" upgrade failed
Error(11133): IP component QsysPrimePro with file "../../hw/rtl/e10/address_decoder/address_decode.qsys" upgrade failed
Error(23031): Evaluation of Tcl script /root/inteldevstack/intelFPGA_pro/quartus/common/tcl/internal/ip_regen/ip_regen.tcl unsuccessful
KhaiChein_Y_Intel
You may use the command line method to upgrade the qsys system without using the GUI
qsys-generate <IP variation file>.qsys
The IP upgrade option is available in Table 172. Command-Line Options for qsys-generate https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-platform-designer.pdf
Do you see any error messages when you launch the GUI?
KhaiY
Hi KhaiY
thanks for your suggestion.
based on the error information from GUI when I was upgrading IP before , I knew 2 ip need to be upgrade manually.
So I close quartus GUI and did below
[root@fig01 e10]# pwd
/root/inteldevstack/a10_gx_pac_ias_1_2_pv/hw/samples/eth_e2e_e10/hw/rtl/e10
[root@fig01 e10]# cd address_decoder/
[root@fig01 address_decoder]# qsys-generate address_decode.qsys
bash: qsys-generate: command not found...
seems command is not found for Intel PAC card OPAE design environment.
any other steps I can try for the platform designer GUI not showing correctly?that is part of design tolls ,which might be used in further development.
thanks
Jim
also I think the upgrading failed issue might be caused by the connections related to module rx_xcvr_half_clk from the printed error information.
it was not only about upgrade flow, but also design itself. this is the vendor provided design example ,I did not modify anything.
thanks
MEIYAN_L_Intel
May I know which Quartus prime software edition and version is using?
Hi MeiYanL
thanks for your feedback.
I am using Quartus Prime Pro 17.1.1 build 273,which is recommended version by the Intel PAC user manual.
Best regard
Jim
Hello Sir/madam,
Based on my recent feedback, can I have some suggestion to solve this platform designer GUI issue and IP upgrading issue?
thanks
Jim
MEIYAN_L_Intel
I had build the design example and I am able to open the platform designer to upgrade the IP component.
As mentioned earlier, the platform designer is hang on initializing page, you may need to follow the instruction as below:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2017/why-does-qsys-pro-hang-at-initializing-qsysipc-bridge.html
Hi MeiYanL,
Thanks for your effort.
I have tried that solution, platform designer was hanging and had no response to clicking of close windows button. Even I quite the Quartus ,platform designer was still there. I had to restart server to kill it.
May I know your Quartus version?
Have a good weekend
Jim
MEIYAN_L_Intel
I tested on the Quartus Prime Pro v17.1.1 software as recommended in the document.
According to https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2017/why-does-qsys-pro-hang-at-initializing-qsysipc-bridge.html, it might be cause by machine load.
You may need to try go to the Quartus menu: Assignments > Settings, then on the left panel select the IP Settings and on the right panel set the "Maximum Platform Designer memory usage" to the max value.
For you information, you could use the task manager to close the Platform Designer UI.
Hi MeiYanL,
I have tried to maximum the memory usage, but can't click ok button since it is not visible and the setting windows is not able to zoo in or zoo out.
MEIYAN_L_Intel
You may need to try the method as below:
1. Resize the monitor with different scale and layout as step below:
-Right-click an empty spot on the desktop.
-Click Personalize.
-Click Display Settings.
-Note the current setting of the "Change size of..." and "Resolution".
-Choose the size and resolution to 1920x1080.
-If the screen looks OK, click "Yes" to keep these display settings.
2. Resize Quartus Prime software front setting as steps below:
-open Quartus Prime software
-click Tools>Options>General>Fonts
Hi MeiYanL,
My graphic card on clinet computer(working from home) supports resolution up to 1440*900 .
with that settings seems not big enough to fit part of Quartus window.
Can I get you compiled project ?
Best regard
Jim
MEIYAN_L_Intel
After update the IP files, I had compile the project file. But there is some error on my side.
I will need some time to investigate for it.
MeiYanL,
thanks for your support, have a good weekend.
Jim
