Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
auto complete on tcsh and bash
ashishkkaul
Could we get auto complete installed on the bash and tcsh shells?
Ashish
Hazlina_R_Intel
Can you let me know which Intel FPGA platform that you are referring to?
And what do you mean by "getting auto complete"?
-Hazlina
ashishkkaul
For example, when you are try to change directories, you can type 'cd' and then use TAB to find files or complete the full name of file or dir after typing first few letters. That is what I mean by auto completion.
It is not working on the bash shell.
Ashish
Hazlina_R_Intel
Noted.
I will have to defer this to the platform expert @Lawrence_L_Intel  - Can you please look into this issue on the Dev Cloud platform?
-Hazlina
Lawrence_L_Intel
Hmm, my bash with a single or double tab works fine for me. There is an article here about bash autocomplete that might help. I've never had to set anything special, it just worked out of the box.
https://www.cyberciti.biz/faq/add-bash-auto-completion-in-ubuntu-linux/
regards
Larry
ashishkkaul
Larry,
We are not allowed to run sudo and for me /etc/profile.d/bash_completion.sh does not exist.
Dear User,
this server does not allow you to run "sudo".
If you need to install a dependency, please put it in your home directory.
* For autotools, you can do it with "./configure --prefix=~/my-path"
* For Python packages, use "pip install <package_name> --user" or create a Conda environment.
Sincerely,
Admins
cat /etc/profile.d/bash_completion.sh
cat: /etc/profile.d/bash_completion.sh: No such file or directory
Lawrence_L_Intel
 I have never seen this one before.  What machine are you on? Perhaps you can save your various dot files .bashrc, .profile etc and copy the defaults from /etc/skel. Let me know if that  works. Thanks
ashishkkaul
This happens on X2GOClient. I am on machine s001-n189. It does not happen when I use a standalone terminal from XQuartz from example.
But there is no /etc/profile.d/bash_completion.sh in either case.
Ashish
Lawrence_L_Intel
I tried x2go s001-n137 and its ok and autocompletes with X2go. can you type env > env.txt and send that file?
ashishkkaul
I have attached the file env.txt
Lawrence_L_Intel
thanks for attaching ... the only thing that jumps out at me is SHLVL=6. that means you are 6 levels deep - perhaps try exiting out to SHLVL=1 . however that is just a guess I'll have to research more.
ashishkkaul
SHLVL=6 is what I get when I open a terminal on my x2goclient desktop.
