Client
Interact with Intel® product support specialists on client concerns and recommendations
48 Discussions
Field Update 1 of 2: Intel Core Ultra 200S Series Performance Status
Intel_Client
4 12 41.4K
Intel® Core™ Ultra 200S Processors (codename Arrow Lake-S) launched at the end of October with significant advancements for multi-threading performance, performance-per-watt, platform I/O, and overclocking. Editorial conclusions on gaming performance were more polarized, with noteworthy statistical variation from one article to the next. These results were inconsistent with our internal testing.
Starting October 26, the team launched a daily investigative effort to understand and address these gaming-specific reports. By November 8, sufficient early indicators had been established to inform a commitment: a public root cause analysis and action plan in 4-6 weeks.
We recently concluded our investigation, and we have determined that there are five distinct topics that could alter performance or functionality:
  1. A missing Performance & Power Management (PPM) package.
  2. Intel Application Performance Optimizer (APO) could not take effect.
  3. BSODs when attempting to launch game titles utilizing the Easy Anti-Cheat service.
  4. Select performance settings misconfigured on reviewer or early enabling BIOSes.
  5. New BIOS performance optimizations.
We are pleased to report that 5 of 5 issues have been root caused, 4 of 5 issues are already solved with updates available to you, and significant performance upside is accessible by applying these updates.
Bottom Line: Apply the latest BIOS updates for your motherboard and update Windows 11 to build 26100.2314 (or newer). New BIOS files with net new performance enhancements will also be available in January to once again improve performance in select games and applications. Intel will publish a complete performance digest, inclusive of the January BIOSes, at CES 2025. You can apply the available updates now or wait for the final performance update in January. The exact performance uplift you individually experience depends on the current patch/update condition of your system, the applications you prefer, and the BIOS/OS/software settings you prefer.
For completeness, a more thorough technical treatment of the issues is available below.
Missing PPM Package
The behavior of a PC processor is highly adjustable by software. In the Windows OS, this is done through Power Plans. These Power Plans have names like Balanced, High Performance, Power Saver, and so on. The plans provided with a fresh OS installation are relatively generic to accommodate a wide range of processors. It is customary for hardware vendors to update these parameters to better fit the underlying silicon, and this is typically performed through Windows Update or a chipset driver.
Missing, incomplete, or malfunctioning PPM updates can negatively impact CPU frequency ramp speed, core parking, C-State entry/exit/latency, and other functional DVFS or power management capabilities.
  • Root Cause: Intel incorrectly scheduled this Windows Update package for user/retail availability, not reviewer availability.
  • Symptoms: Unusual CPU scheduling behaviors; artificial performance increases when cores are manually disabled or affinitized; high run-to-run variation in benchmarks; reduced single-threaded scores or performance; intermittent DRAM latency spikes (~1.5-2.0x expected); and unexplained performance differences between Windows 11 23H2 and 24H2.
  • Performance Cost: Approx. 6-30% (estimated), depending on workload or parallel issues present in the system.
  • Status: RESOLVED in Windows 11 build 26100.2161 (KB5044384).
Intel APO Could Not Take Effect
Intel Application Performance Optimizer (APO) is a software-level feature that performs real-time thread scheduling optimization within the game and operating system to improve performance. A high-level goal of this technology is to help games make core/thread scheduling decisions that better fit our hardware, thus raising performance.
Not every game benefits from APO, so titles are enabled on a case-by-case basis as per-game profiles. These profiles depend on the CPU core/thread availability working as intended. If APO cannot detect the expected environment, its performance benefit cannot be realized.
  • Root Cause: The missing Intel PPM placed the processor into an aberrant state where APO could not take effect.
  • Symptoms: No performance gain observed from A/B testing APO on enabled titles.
  • Performance Cost: Approx. 2-14% (estimated), varying with title and/or parallel issues present in the system.
BSOD When Launching Easy Anti-Cheat Titles
  • Root Cause: A known issue between Windows 11 24H2 and the April 2024 (or older) Easy Anti-Cheat driver bundled with PC games.
  • Symptoms: A system halt and blue screen when attempting to launch a game that utilizes Easy Anti-Cheat software.
  • Performance Cost: None, functionality impacted
  • Status: RESOLVED. Epic Games is actively distributing an updated Easy Anti-Cheat driver to impacted developers and publishers. The updated Easy Anti-Cheat driver will be pushed as a game update via digital delivery services.
Select Performance Settings Misconfigured in Reviewer BIOSes
Modern gaming PCs benefit from several performance-enhancing firmware capabilities that are exposed by or dependent on modules in the system BIOS. For Intel, these settings include: PCIe® Resizable BAR, Intel APO, compute tile ring frequency, memory controller ratio (“gear”), sustained/transient power limits, and more.
Intel identified that one or more of these “VIP settings” were not consistently toggled to the most performant state if the user restored default BIOS settings during the review period. Some preview BIOSes had only one of these settings misconfigured, some had more than one setting misconfigured, and some had default settings change between preview BIOS releases.
  • Root Cause: Consistency of VIP settings not sufficiently re-validated or enforced by Intel.
  • Symptoms: Aberrantly high memory latency (~1.5-2.0x expected); erratic or fluctuating compute tile ring frequency; high run-to-run stdev for dynamic or unpredictable workloads; no performance uplift for games that benefit from PCIe® Resizable BAR; no performance uplift for games that benefit from Intel APO.
  • Performance Cost: Approx. 2-14% (estimated), depending on application and/or BIOS setting.
  • Status: RESOLVED. Current BIOS releases for Intel Z890-based motherboards have harmonized these settings.
New BIOS Performance Optimizations
As a result of our daily investigative efforts since October 26th, Intel has additionally identified a small selection of performance optimizations that are recently developed, or were not ready for the motherboard BIOS images released thus far.
This fifth and final category of performance update requires a new firmware image that is currently undergoing Intel validation prior to customer release. We expect user-facing BIOSes to be released in the first half of January 2025. Exact availability will depend on the test and release schedule for your specific motherboard. The correct BIOSes will be identified with Intel microcode version 0x114 and Intel CSME Firmware Kit 19.0.0.1854v2.2 (or newer).
Conclusion and Next Steps
  1. Intel has fully resolved 4 of 5 issues that impacted performance or functionality during the launch of the Intel Core Ultra 200S processors. Complete and intended functionality is restored.
  2. These updates are immediately available: update your motherboard BIOS and apply Windows updates until reaching Windows 11 build 26100.2314 (or newer).
  3. The fifth and final performance update requires additional firmware updates, which are planned to intercept new motherboard BIOSes in January 2025. We advise that this update will provide another modest performance improvement in the single-digit range (geomean, ~35 games). These BIOS updates will be identified with Intel microcode version 0x114 and Intel CSME Firmware Kit 19.0.0.1854v2.2 (or newer).
  4. The exact performance uplift you will experience with these updates depends on the specific issue, or combination of issues, present on your system when your data was originally collected. Results also depend on your selection of games or applications. Some issues are more elusive than others, more relevant to certain workload characteristics, and/or intermittent in nature.
  5. Intel will provide a comprehensive performance update to the media, inclusive of all the above solutions, at CES 2025. We intend to provide a full performance sweep of games and applications, issue-by-issue A/B analysis, and combinatory analyses. This will be Field Update 2 of 2.
  6. Intel has implemented a selection of new practices, policies, and procedures that will prevent these issues (or related/similar) from reoccurring.
Finally, we would like to thank the reviewer and user communities for their generous feedback. Whether it was sharing performance traces and test data, or conversation on services like Reddit and Bluesky, this feedback helped us triangulate the right answer for complicated issue spaces. You have our gratitude.
Very sincerely,
The Intel Client Team
Footnotes:
  • Results that are based on pre-production systems and components as well as results that have been estimated or simulated using an Intel Reference Platform (an internal example new system), internal Intel analysis or architecture simulation or modeling are provided to you for informational purposes only. Results may vary based on future changes to any systems, components, specifications or configurations.
  • Performance varies by use, configuration, and other factors. Learn more on the Performance Index site.
  • No product or component can be secure.
  • Your costs and results may vary.
  • Intel technologies may require enabled hardware, software, or service activation.
About the Author
Not an Intel employee
12 Comments
Barrok
I am on the latest Windows:
26100.2605
24H2
Windows 11 Pro
I am still getting the 1.5x latency issue. I usually sit around 75ns but after a few games of Battlefront 2 (star wars game) it almost always will jump up to 130+ (right now it is 135, testing through AIDA64 Extreme).
More than happy to help provide any other bits of info that may be useful.
Please let me know! I would love to get this solved (only issue with the CPU I have so far)
HueSplat
Can we get more information on Intel CSME Firmware Kit 19.0.0.1854v2.2?
What is the full firmware and sub-firmware/plugin version list of Intel CSME Firmware Kit 19.0.0.1854v2.2?
What changes or updates to the ME firmware contribute to the performance increase?
Are there any firmware changes other than the microcode and CSME firmware?
Are you also revising or making changes to the Intel ME driver?
DigitSystem
Hello all!
I am an Intel fan, the last 20 years owns only Intel CPU's, never had problems. Last week changed my i7-13700kf to Core Ultra 7 265kf - Coolermaster 240L water - MSI MAG Z890 Tomahawk -G.Skill 7800 cl36 32Gb- Gainward RTX4090. At the moment I am very disappointed, the system is unstable, unusuable. Crashing many many times when playing PUBG (playing with that game only). Today changed the memories to a Kingston 5200 cl40 16Gb, it was more stable, but when I tried to run a cpu bencmark (userbencmark.com) crashed again.
In the game there is FPS drops 175 to 145-155. The game feels "laggy" , can not explain exactly, but it feels like a 10th gen i7.
At the moment -in my opinion- that was a big mistake to change my config to 265KF.  (maybe Ryzen 7 9800x3d?)
There is the hottest BIOS firmware / windows update / all drivers updated, in the BIOS setting all is normal/default/xmp2 , no any tuning or OC. Using CPU/GPU thermo meter , the temperatures is more than good. (CPU temp about 53-58 celsius, ingame)
Dear Intel!
There will be some kind of more speed / stable upgrade for this platform?
It was not a cheap config, anybody else have the same issues?
DragonSentinel
https://asrock.com/mb/Intel/Z890%20Taichi/index.asp#BIOS
I tried ASRock's AS03 beta BIOS, which included updated microcode 0x114 and updated firmware 19.0.0.1854V2.2. However, there was no change in benchmark results compared to previous versions, and in some game benchmarks, the results were lower. This is surprising. A solution should be considered promptly.
AS02>>33689
AS03>>32413
DigitSystem
Dragonsentinel, yours is not bad bro' !Dragonsentinel, yours is not bad bro' !
DragonSentinel
My 285K is a high-quality chip within the top 1%. The 2nd Core Ultra generation is a CPU that cannot be appreciated at all, even with a chip in the top 1%. Despite the promised updates, it has backfired. To put it bluntly, it's like a 'diarrhea-like poop CPU.' In short, 'Diarrhea CPU.
DragonSentinel
Feeling responsible, ASRock removed all information about BIOS versions prior to 0x114, including BIOS 0x113. Could this have been due to strong pressure from Intel? Everything was supposed to go smoothly with the update to 0x114 and the new firmware. However, it seems to have ended in the worst possible finale.
DragonSentinel
The image compares the scores of Cyberpunk 2077 as measured by pcgamesn.com.Please verify this. At a resolution of 1920x1080, the 285K scores on par with the 9800X3D. However, this result is from before the application of the 0x114 microcode and firmware 2.2 updates. This suggests that the microcode and firmware updates have no significant impact.
DragonSentinel
The PCER24 CPU mounting frame is exceptionally well-crafted and is manufactured in a factory in Japan. The product is made from 99.9% pure copper material, giving it a beautiful appearance and meticulous workmanship. According to Thermal Grizzly's verification, even using the countermeasure ILM adopted by motherboard manufacturers cannot avoid warping. After using the mounting frame, the temperature recorded during Cinebench 2024 measurements was below 80 degrees Celsius.
It's intriguing how standard ILMs (Independent Loading Mechanisms) from motherboard manufacturers might not fully prevent CPU warping. Warping can lead to uneven contact between the CPU and the cooler, resulting in inefficient heat dissipation and higher temperatures. The PCER24 mounting frame, with its pure copper build, seems to address this issue effectively. Pure copper is known for its superior thermal conductivity, which likely contributes to the impressive temperature reduction observed during testing.
Recording temperatures below 80 degrees Celsius under a heavy load like Cinebench 2024 is remarkable. It not only indicates better performance but also suggests enhanced longevity for the CPU due to reduced thermal stress. This could be particularly beneficial for users engaged in high-performance tasks or overclocking, where heat management becomes crucial.
It's also worth considering how third-party solutions like the PCER24 frame push the envelope beyond standard manufacturer components. They often incorporate higher quality materials and refined designs that can make a significant difference in performance. Exploring such options might open up new possibilities for optimizing your system's thermal efficiency and overall performance.
If you're interested in further enhancing your CPU cooling setup, you might also look into liquid metal thermal compounds or custom loop liquid cooling systems. These can offer even greater heat dissipation but come with their own sets of challenges and considerations.
ssauma
Likewise I have a 285K in an AsRock Z890M and the 2.21.AS03 bios containing 0x114 and CSME update IS BROKEN- completely broken and results in a performance regression IF IT EVEN BOOTS.
DigitSystem
I sent back my Ultra7 to the seller, and changed to Ryzen 7 7800X3D , it easily beats the Ultra 7, and same price. Waiting for 9800x3d to buy, but at the moment very rare/overpriced that CPU. Sadly, I was a old school Intel dude, but very disappointed with Ultra series...slow,unstable ,for high price. If u want I can upload benchmarks/tests. Have a nice day .
kcw
@Intel_Client Any thoughts on the BIOS and Windows update? Miscommunication with Taiwan board partners?
Can someone post benchmark that has all three criteria checked (0x114, ME1854v2.2, Windows 11 26100 2314 or newer)?
