Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
548 Discussions
Extended displays for digital signage
computerpaul
Hi
We are a software developer, directtv.com.au. We need to connect a single PC or embedded system to two side by side displays, where the video extends across both displays.
Although Windows automatically supports extended monitor mode for windows from simple aps like Word etc, it does not work propery with Media Player and in particular our software.
We think we might try using IEGD to make a custom video config file but we are not sure whether this will work
Has anyone done anything similar to the above?
Chris_M_Intel
ComputerPaul,
Extending video (by this I mean things like movies) across two displays will be problematic. The display is part of the pipeline for the media player. If you limit the multiple display option to just one adapter (for example, dual display from a single part) that will eliminate some of the problem. You would also have to figure out how to handle things like overlay of which there is generally only one, and therefore would only work on one of the displays. Protected content would have a hard time with this as well. In general, I don't believe this is something that Windows software can actually do. If you're using a custom-built media-player, didn't use DXVA,and just used the CPU for decode and playback I think you could get it to function, mostly, with a lot of work...
Chris
ralf__
Quoting - Fendriss
ComputerPaul,
Chris
ralf__
Quoting - Fendriss
ComputerPaul,
Chris
ralf__
Quoting - Fendriss
ComputerPaul,
Chris
sorry for all those mis-clicks,what i really want to know is,how to use dual view clone mode output interface in your graphic driver,i've been able to use extend mode by windows API ChangeDisplaySettingsEx but clone mode with(LCD+CRT),can you tell me where can i get the specifications of 945 serial graphic card driver sw manual,3Q.
delacy__david
Quoting - ralf__
ChangeDisplaySettingsEx doesnt know what clone mode is
xp doesnt know what clone mode is
intel must have some documents on how to control what clone mode is and how to set it through their CUI
but i havent seen those docs
delacy__david
Quoting - beerandcandy
oh and i think fendris is a bad man!!!
Chuck_De_Sylva
We're looking into this for you. We're not sure whether or not this is still supported.
