Edge Software Catalog
476 Discussions
Device Manageability feature
Mauricio
Hi everyone,
I am automating the process of installing and configuring the device management feature.
I have founded some errors:
1) The update step, can sometimes fail.
So, my workaround is replace the lines with this one:
apt-get update >&/dev/null || echo 'no-possible-update'
in the install-tc.sh file.
2) On Ubuntu 20.04, I having an issue related to trtl:
Now, I am having a problem with trtl package:
** Will install MQTT Service.
Selecting previously unselected package mqtt.
(Reading database ... 195506 files and directories currently installed.)
Preparing to unpack mqtt-2.13.2-1.deb ...
Before install called
Found systemd; attempting to stop any prior mqtt service
Unpacking mqtt (2.13.2-1) ...
Setting up mqtt (2.13.2-1) ...
After install called
chmod: cannot access '/lib/systemd/system/systemd/system/mqtt.service': No such file or directory
Found systemd; attempting to start mqtt service
Ran systemctl daemon-reload
MQTT Installation Complete
Will install trtl executable
Selecting previously unselected package trtl.
(Reading database ... 195534 files and directories currently installed.)
Preparing to unpack trtl-2.13.2-1.EVAL.deb ...
Unpacking trtl (2.13.2-1) ...
Setting up trtl (2.13.2-1) ...
AppArmor detected. Activating trtl's AppArmor policies.
AppArmor parser error for /etc/apparmor.d/usr.bin.trtl in /etc/apparmor.d/usr.bin.trtl at line 6: Could not open 'abstractions/lxc/container-base'
dpkg: error processing package trtl (--install):
installed trtl package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
trtl
Issue with installation. Will force.
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
chromium-codecs-ffmpeg-extra gstreamer1.0-vaapi libgstreamer-plugins-bad1.0-0 libva-wayland2
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
dpkg: error processing package trtl (--configure):
trtl
E: Sub-process /usr/bin/dpkg returned an error code (1)
make: *** [Makefile:35: install-tc] Error 100
Do you know why I get this error?
Mauri Aguilar.
JesusE_Intel
Hi Mauri,
Thanks for reaching out. The Edge Insights for Industrial software package and the Device Manageability list Ubuntu 18.04 as a pre-requisite. Could you try this process on a Ubuntu 18.04 system and let me know if you continue to have this issue?
Jesus
Mauricio
Hi Jesus,
I have had the same error on Ubuntu 18.04.
My workaround was:
sudo apt remove --purge apparmor
reboot
sudo apt install apparmor
but I am not sure that was the solution.
I have been problems with the services:
apparmor.service
trtl
configuration.service
mqtt.service
In this moment I do not have this errors.
If I install turtle creek every time I use it, I do not have this errors.
Mauri
JesusE_Intel
Hi Mauri,
Edge Insights for Industrial version 2.6.1 is now available, could you check if you run into the same error on this release?
Jesus
JesusE_Intel
