Edge Software Catalog
475 Discussions
Dump-capture kernel not executed for NMI kernel panic
bmh8x
Hi all,
When using ECI 3.0.1 Debian 11 (Bullseye) distribution, the dump-capture kernel not executed for NMI kernel panic by WDT(watch-dog timer) timeout, and I cannot get the kernel dump file.
On the other hand, kernel dump work with the orther non-IRQ kernel panic (ex: kernel panic occurred when writting to /proc/sysrq-trigger), and I can get the kernel dump file.
I am using Intel ECI 3.0.1 Debian 11 distribution(kernel version: 5.10.140-rt73-intel-ese-standard-lts-rt+) , and I think this is the same as the bug in the following report( This bug is fixed in kernel v6.1 )
      https://lore.kernel.org/all/2c243f59-6d10-7abb-bab4-e7b1796cd54f@jv-coder.de/
      Subject: [BUG RT] dump-capture kernel not executed for panic in interrupt context
Please provide me some information on how to fix the kernel dump function for IRQ-triggered kernel panic in ECI 3.0.1
Best regards
Bui
Lay
Hi @bmh8x
Yes, I saw the patch is only available in kernel v6.1
https://github.com/intel/linux-intel-lts/commit/05c6257433b7212f07a7e53479a8ab038fc1666a
Can you manually patch the file in kernel 5.10 and see whether it's work?
Lay
JesusE_Intel
Hi Bui,
Apologize for the delay in our response. I am escalating your question to the development team for further assistance.
I will let you know once I hear back.
Jesus
bmh8x
Hello Jesus,
Are there any updates on my question?
Bui
Lay
Hi @bmh8x
Lay
bmh8x
Hello Lay,
          >Can you manually patch the file in kernel 5.10 and see whether it's work?
→ Thanks for your advice. I will try and let you know the result later
Bui
JesusE_Intel
